parts list for V6 5 Speed car to LS2 Auto!!!! I need a complete list of things i would need. Would a ls1 harness work with the extensions or better off getting a ls2 harness, k-member, crossmembers for tranny, any other stuff just list me all of it!!!!!!!!!!!!!!!!!! |
DO IT!!! 6 to 8, you'll appriciate 7 Attachment(s) Did the V6 5spd to LS1 A4 in mine, All the swap parts came off of 98 trans am that got rear ended. heres wut i can tell ya on a swap. Entire LS harness, basically headlight to taillight (find V8 parts car) PCM for LS Auto if you get V8 6spd, you can get it re programmed K-member is the same its the V8 suspension thats diffrent i believe Fuel lines, gas tank W the V8 fuel pump(fuel lines and pressure diffrent) Rear end- V8 rear so you dont have a "1 wheeled wonder" and i think ABS and the wiring is little diffrent Convert the pedal assemly, speedo, shifter(sucks cuz u have a big hole now) A4 crossmember radiator, cooler lines :bang: Wiring is not as bad as u would think, if the pigtail doesnt fit = its wrong and more than likely will only plug into 1 wire which is right The rest of the stuff is all bolt in! easy :nod: If You do the swap your self you will take your whole car apart like the pic of mine "Stripped" But you will know every bolt and wire... which is never a bad thing! :chug: My 2 cents, take your time and look for a good totaled Fbody, Camaro or Bird doesnt matter. Payed 2 grand for this car :D, front clip perfect! interior flawless! tons of good parts. Peicing together is a pain and some times is alot of money |
1 wheel wonder? I want to do the same swap but by what do you mean the "1 wheel wonder?" when i do burnouts with my camro 1998 v6 i leave 2 marks. If soemone could explain id appreciate it. |
© 2024 MH Sub I, LLC dba Internet Brands
