Does anyone have a used G.M vette filter/reg that I can try? I keep on blowing aftermarket filter/regs and want to try a G.M filter instead,but I want to try one and see if it blows up before I go and buy a brand new one. Thanks. |
Somethings not right if your blowing them up. Whats your setup? |
is your return line to the gas tank plugged?? |
everything is in the right spot with no kinks or obstructions.I am buying the regulators at partsource and they can't handle a performance pump. |
I know of guys running 1200hp aeroquip pumps on the WIX filters. I have a hard time believing the filter is at fault. Again, whats your setup? |
Jay Rod, I run a wix on my setup. I started it today for the first time, and have had no issues. There has to be an issue with the return... Jack |
The return line is flowing fine.All of the fuel that the pump is moving is going through the return and back to the tank and no psi up to the rail.I have put a ball valve on the return so I can build enough pressure at the rail.I have the filter hooked up as follows.3/8 male IN 3/8 female OUT 5/16 return. I truly think that the partsource filter is of poor quality and I want to try a different brand.I just want to make sure that is the problem before I spend even more money. Thanks. |
Originally Posted by JAY ROD
(Post 9294002)
All of the fuel that the pump is moving is going through the return and back to the tank and no psi up to the rail. |
I would like to know what is causing this, when you finally figure this out. Definitely get back to us on this one! thanks |
Any news yet, as to what the cause was? Thanks |
I put a regulator on it instead.I am sure a G.M filter would have worked but if it didn't I would have been out another $70. I bought an adjustable fpr and the car runs like a champ. |
It sounds you had the lines swapped on the end of the filter with two fittings if you were using a 99-07 C5 filter. If you had the return on the inlet and vice versa that could happen. Or just faulty filters but that would be an oddball. Good you get it working with a different setup. Mike Norris |
The lines were right,I made sure and read every post on where the lines go.3/8 male in,5/16 male return,3/8 female out. |
© 2024 MH Sub I, LLC dba Internet Brands
