LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Conversions & Swaps (https://ls1tech.com/forums/conversions-swaps-28/)
-   -   MIL & TCC Q's (https://ls1tech.com/forums/conversions-swaps/935440-mil-tcc-qs.html)
Chizel Jun 10, 2008 01:05 AM
MIL & TCC Q's
So from some research I have done on here, I take it that the MIL wire is for my check engine light? Is that correct? If so, is there a certain bulb that has to be wired to it, like can it be an LED or does it have to be a conventional style, etc. Also, is it a hot wire when the light is on, meaning all I need to do is hook the MIL wire up one side of a bulb and a ground to the other and I am good?
Next question is similar to the first, in that what does the TCC wire hook to make it work? Is it constantly energized and has to hook to a brake switch that cuts power when engaged, or vise versa? Anyone?? Thanks!!
G-Body Jun 10, 2008 01:38 AM
Yes its for the check engine light
I don`t remember if you can use a LED or not, I know there were a couple threads about it, don`t know if a definite answer was reached.
Too hook a light up, hook one side to the MIL wire and the other side to an IGN + wire
Yep, you have it exactly, hooks to ignition + (12V with ign on) and cuts power when brake depressed
TomH Jun 10, 2008 07:24 AM
To be clear, the MIL light is wired "backwards" from the typical bulb installation. The MIL feed from the PCM provides a ground signal, so you will need to come up with a separate 12V(+) accessory feed.
Good luck.
Rodder Jun 10, 2008 10:04 AM
LED works fine for MIL, just make sure the anode goes to the PCM. The only thing that can't use an LED is the alternator warning light (on applications that have one).
tk-mpl Jun 10, 2008 12:38 PM
If you use a LED you will have to put a resistor on the positive circuit to drop the voltage.
Rodder Jun 10, 2008 03:37 PM
unless it's a "12V" LED that has a built-in resistor.
1987earthquake Jun 12, 2008 01:04 PM
I'm confused now. Does the tcc wire connect to the output of the brake switch?
rockytopper Jun 12, 2008 02:30 PM
The tcc needs to see +12v except when the barke is engaged. older car brake switches want work but I have seen this one on ebay for the ls1 application.
http://cgi.ebay.com/ebaymotors/TCC-B...spagenameZWD1V
Thanks guys it appears I have my mil light wired backards.
1987earthquake Jun 12, 2008 08:38 PM
I just went to autozone and picked up a 1996 firebird brake light switch with 6 wires. It controls the brake light and the tcc. Got it for $5.99!
rockytopper Jun 14, 2008 08:47 AM
Thanks again guys, I switched the mil wire and now my check engine light comes on when I turn the key on and goes out when I start it. Now I comformation that all is well sense the light is going off as it should be. This forum rocks.
© 2026 MH Sub I, LLC dba Internet Brands
