Question about radiator, fans -LS2 into 97 Camaro
Hi all,
I know this has been talked about a great deal, but I couldn't really find a clear cut answer. I've heard that you can keep the LT1 radiator, fans and condenser when making this swap, but you have to block off one of the holes in the radiator? Is everything else the same? My other concern is, what do you use for a cold air intake/filter setup? If I kept the LT1 stuff, would I have to have something made to connect my K&N FIPK to the LS1 throttle body? Obviously the LS1 style lid won't fit over the LT1 radiator and fans, or will it if that shroud that goes over them on the LT1 is taken off? Any help is greatly appreciated. Thanks for looking!
Brian
Brian
