Will an F-body alternator fit on a C5 alternator bracket? I'm trying to get powersteering and AC, and I think if the F-body alternator will bolt up to the C5 bracket it will work. I remembered they looked about the same, but the F-body alternator only had one wire. |
That's just the Connector..only one wire is pinned. They all look the same, I'm wondering as well.. |
If the alternator has 2 through bolts and not one of them tapped for a bolt, it should work. Even the alternators on the 4.3's like in the later model S10's and Astro vans should work, as long as they use the through bolt mount holes |
Will some one measure the distance between the two bolt holes on the camaro alternator? That might make it easier for a vette guy to compare to. |
When I did my swap I had to use the corvette alternator. The camaro alternator is not even close to bolting on the corvette bracket. |
© 2024 MH Sub I, LLC dba Internet Brands
