LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Conversions & Swaps (https://ls1tech.com/forums/conversions-swaps-28/)
-   -   What's wrong? (https://ls1tech.com/forums/conversions-swaps/989739-whats-wrong.html)
joshluther Sep 21, 2008 03:08 PM
What's wrong?
The car will only fire with the fuel pump diconnected...
I turn the key on and it primes the pump, crank , no fire. Disconnect the pump trigger wire it will fire but die unless I reinstall the trigger wire..
Once I get it fired and hook the pump back up it runs fine...
SatisTraction Sep 21, 2008 09:58 PM
sound like you have a wire that is not hot in crank and run.
joshluther Sep 22, 2008 03:57 PM
I have checked them, all is good.
From my understanding the pcm only turns the pump back on after it sees a start condition.
The car will only start if I disconnect the fuel pump relay trigger wire.
Jones'n Sep 22, 2008 04:04 PM
Maybe the relay is wired wrong?
joshluther Sep 22, 2008 07:16 PM
I figured it out. I had a wire that was only 5 volts when cranking. I remember reading about this and I thought I had jumpered correctly but satistraction's post made me double check it with a volt meter.
https://ls1tech.com/forums/showpost....82&postcount=8
© 2026 MH Sub I, LLC dba Internet Brands
