Gen V LT1 tr6060 into 4th gen
Parts I know I need:
LS1 k member
holley LS to gen V motor mount adapters
Holley or aftermarket gen V retrofit oil pan
petal assembly
New headers, having a hard time finding gen V headers for 4th gen, who makes them?
X pipe and some sort of new exhaust
Parts in question:
do I need the Holley conversion oil pan if I have the tubular k member? Or if I do the conversion oil pan can I use a stock ls1 k member?
Can I use the gen V harness and guages, or do I need/better off with a Holley terminator?
What is the ignition key situation? Do I need a new column?
new radiator and fans?
Have a walbro 255 now but what else for fuel system?
Any reference builds around? Only one I found dead ended. Pic of car for reference, want it to stay looking like a shitbox for now. Have had the car for 20 years and wife agrees it’s time to make it useable again for me to drive to work trips instead of just rotting away in my enclosed trailer and buying another car.
The one I’m stuck on is headers. I havnt called any companies yet but from what I’m reading LS headers don’t fit, and I can’t find any long tubes for a gen V LT1 in a 4th gen. Do you have a link or how to search for chris1313? I have an old ls1 lid cold air scoop from him from 20 years ago.
Also fuel system, maybe the walbro 255 is enough supply but don’t know enough about other adapters or the DI fuel system. Would be nice to put in a plastic higher gallon LS tank if I can find one but not a necessary part of the build.
Over ambitious hope is to have all the parts here, and in 1 weekend get it done, in a 2 car garage. I’ve swapped the motor on this car a couple times before, take it out the bottom, slide old out, new in, this time it’s going from a gen II to a gen V so little more wiring involved. Not like it’s a DD but I do have 3 kids I don’t need touching **** when it’s half apart.
