Convertible Vehicles Enthusiasts | Information | Maintenance
another tire size question​
Old 04-25-2017, 05:57 PM
zman02's Avatar
Default another tire size question​
On an 02' Camaro convertible, will a 18x10.5 56 mm offset fit with nitto 555r in 305. With 35 or 40 profile.
Old 04-26-2017, 06:15 AM
farmington's Avatar
just put on a 555r 285-35-18 on a 9.5 wheel and had plenty of clearance.
Old 04-26-2017, 08:07 AM
DANOZ28's Avatar
im probably crazy but i like my stock chrome 16" wheels, im looking to get another pair and add some drag tires. whats the largest size tire that will fit that rim and not cause tire rub? thx sorry for the thread jack!
Old 04-26-2017, 08:50 PM
farmington's Avatar
you can't go any bigger than a 250-50-16 because there are so few choices. Mickey Thompson makes a nice tire, it hooks better than the Nitto's but will be a little harder on your rear end too.
Old 04-27-2017, 10:42 AM
zman02's Avatar
I already have the rims but didn't know if 305 or 315 or 295 would work without too much difficulty. I haven't​ purchased the rubber yet. Obviously I'm no different than most I want as wide as can fit.
Old 04-27-2017, 11:11 AM
SoFla01SSLookinstok's Avatar
I also have 18x10.5 rear rims. Not positive on the offset but they stick out further than stock. I think I had them add the 1" in extra width to the outside of the rim. I just installed 305/40 18 555r DR. Clears ok, no rubs or contact anywhere. Stock ride height.
Old 04-27-2017, 05:43 PM
zman02's Avatar
​​​​​​​so with the 40 profile that makes it approximately 27.5 tall. You don't have any rubbing on full acceleration?
Old 04-27-2017, 05:56 PM
Correct. I think the unloaded OD is around 28". No rubbing any time. If you want I could snap some pics.
Also, my lower control arms are in the lowest relocation hole. So I don't think my car squats much. Just wanted to note that.
Old 04-28-2017, 09:41 PM
bad_408_vert's Avatar
When I was exploring , I used this tool to figure out things like over all height of new wheel/tire combo vs old stock set up.
https://tiresize.com/height-calculator/
Old 04-28-2017, 10:23 PM
I'm putting on a 295/40/17 on 10.5" wide wheel tomorrow.
Quick Reply: another tire size question​
