LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Corvette Performance (https://ls1tech.com/forums/corvette-performance-27/)
-   -   So I'm Looking for 500whp (https://ls1tech.com/forums/corvette-performance/1038692-so-im-looking-500whp.html)
TransAmcoupe98 Dec 26, 2008 10:24 AM
I'm going to be upgrading again with a healthy sized cam along with some nitrous and I am looking to be at around 500whp. At that power level, what is prone to go wrong with these BESIDES the engine internals. I'm talking about axles, splines, tranny, rear, suspension? Any feedback is appreciated.
dixonk Dec 26, 2008 04:02 PM
At that power level I would say tranny, clutch, output shaft more than likely. The rest is hit or miss.
Nwmembr19 Dec 27, 2008 04:16 PM
I havent had any problems, but i've only been to the track twice since putting the engine in, and I dont launch hard.
OKcruising Dec 27, 2008 05:32 PM
Highway rolling? stock driveline
street/strip? basic driveline mods
serious drag? built rear and brace and adjustable shocks
VGLNTE1 Jan 3, 2009 03:04 AM
clutch will be shot soon for sure. everything else is just when the time comes. could be your first launch, or your 3000th
marlowchris Jan 6, 2009 09:36 AM
Based on my experience, once you start drag racing things will break in the following order:
1) Clutch
2) Output shaft
3) Trans
After that it can be any of the following: rear end, engine(probably pistons or rods), torque tube bushings.
You get the idea. So you can either just wait until they break and fix them then or replace everything now. How much money do you have?
I had a bad run of luck last year and had to replace the following:
forged engine, trans, rear end, rebuilt torque tube
1.8t Jan 6, 2009 10:08 AM
If you aren't a serious drag racer, the only thing I would worry about is the clutch. If you are serious about dragging, then you know what you will need to upgrade.
© 2026 MH Sub I, LLC dba Internet Brands
