what engine comes in a 02 corvette??? is it an ls6 |
Ls1 with an LS6 intake |
Originally Posted by sl99ls1
(Post 12498777)
is it an ls6 C5Zo6 comes with an ls6 block/ls6 intake/ls6 heads/ls6 cam/better oiling. Of course there is more to it, but that is the basis. |
Originally Posted by lemons12
(Post 12499040)
Base model comes with an ls1 block and ls6 intake. C5Zo6 comes with an ls6 block/ls6 intake/ls6 heads/ls6 cam/better oiling. Of course there is more to it, but that is the basis. |
02 Corvette-LS1 02 Corvette Z06-LS6 |
I believe that you will find that the 02 ls1 uses the same block as the ls6 (diff heads and cam) and of course the rest of the short block is the same between the ls1/ls6. |
(Post 12499040)
Originally Posted by M_T_0
(Post 12508393)
better oiling I never have heard of that where did you get this info? my understanding is that the only diff outside of the heads after 2001 was the cam and the computer tune and that even the oiling componets were carried over to the base ls1. The ls6 has slightly better oil flow and in the main webs between the cylinders there are cutouts that are supposed to allow the air to flow from one cylinder pair to the other at high speeds to prevent too much pressure on the underside of the piston. GM said it's supposed to alleviate some of the parasitic draw that pressure below the piston in the crankcase causes at high speeds. LS6 block has better bay-to-bay breathing than the earlier LS1 block also. the blocks have a hole machined thru the main webs to improve bay-to-bay breathing. the hole cures the bay-to-bay oil vapor pumping issues |
coup & convertible LS1 = 350 HP Z06 LS6 = 405 HP |
(Post 12499040)
(Post 12510495)
I read an article or something of the sort at one point. Research a littlie and you will find plenty of info on it. |
© 2024 MH Sub I, LLC dba Internet Brands
