Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
difference: stock flywheel vs fidanza aluminum flywheel
Old 10-16-2010, 12:58 PM
427LS7HCI's Avatar
Default difference: stock flywheel vs fidanza aluminum flywheel
2 H/C/I C6s with the exact same combos and both 6spds and same gearing. The only difference being one with a stock LS7 Clutch/flywheel and the other with a fidanza aluminum flywheel/spec 3+ clutch. From a 60-130 roll, will the C6 with the aluminum flywheel beat the factory flywheel'd C6?
Old 10-16-2010, 06:07 PM
SCM_Crash's Avatar
Technically speaking, yes. Less spinning mass means less power loss. How much power are you actually losing? Not much. Maybe 2-5HP. Will you SEE the difference? Probably not. Some people claim they see 10HP differences. Maybe. But we're talking the difference of about 0.01 in the 1/4 mile. Maybe a little more... But honestly, aluminum flywheels are the week link in a drive train. Get a chromemoly flywheel if you want it to be light and still strong.
Old 10-16-2010, 06:13 PM
pittman's Avatar
The other side of that is the aluminum flywheel, typically takes a higher rpm to launch as quick as a steel flywheel. I have run both many times. I love the way the aluminum flywheel lets the motor rev and drop off rpm so quick.
Old 10-17-2010, 01:52 AM
c6r
c6r's Avatar
I have a aluminumflywheel setup...an I am strong from a role race period...makes a difference from a role for sure if you do a lot of the 40 to 140mph type of stuff
Old 10-19-2010, 08:53 AM
pontiac's Avatar
the aluminim is the way to go, make the car MUCH more responsive and does produce a little more power, but it pulls through the gears alot faster.
Old 10-20-2010, 04:40 PM
demarco313's Avatar
This is a good topic as im trying to consider what Clutch/ Flywheel etc. im going to get on a c5 H/C/I/E.
I know the aluminum Flywheel is weaker but the question is how much weaker?
SCM CRASH i see you say chrome is best for being light and still strong
Old 10-20-2010, 04:58 PM
NoTractionLS1's Avatar
I would call Jason at TDP. Me and all my buddy's are using his Stage 3 Clutch and A lightweight 15lb 4140 billet chromoly flywheel and I would not change it to any other set up. Feels stock and still pulls like a freight train at rolls and holds up to 5k dumbs at the track.
Here is a link, Just go to the Clutch Kits link when you get on the page.
http://www.texasdrivetrainperformance.com/
Old 10-20-2010, 07:35 PM
ChucksZ06's Avatar
Yes it will beat it by probably one or two car lengths. I have a fidanza in my 403 z06.
Old 10-24-2010, 04:08 AM
JudgeGuns's Avatar
Cool
aluminum flywheel for road racing, steel for the drags
Quick Reply: difference: stock flywheel vs fidanza aluminum flywheel
