LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Corvette Performance (https://ls1tech.com/forums/corvette-performance-27/)
-   -   Over rev'd engine, check engine light now on. Suggestions (https://ls1tech.com/forums/corvette-performance/1352790-over-revd-engine-check-engine-light-now-suggestions.html)
R6cowboy Nov 13, 2010 02:27 AM
I slipped in quite a dumb move today in my stock '00 6spd. Accidentally slipped the trans in 2nd gear and "over rev'd" the engine. I was moving about 80-85mph when it happened. Let out the clutch, heard the motor over rev and instantly pushed the clutch back down. Right after, the check engine light came on and the display read something about reduced power. Car gradually slowed down (would not accelerate) and motor sounded like it was "missing" quite badly. Temp and oil gauges stayed normal. I pulled over about 1/4 - 1/2 mile from where it happened, shut the car off and checked under hood and under car for leaks, no leaks. Started the car back up after a few minutes, ran/idled rough but it did stay running. Drove the car about 1/2 mile to a safe location. All gauges stayed normal, check engine light stayed on and the car would accelerate but ran sluggish. The motor wasn't making any "knocking" noises, but more like a "thud" noise like it was running on 4 cylinders. When I arrived to a safe parking location the car did idle but very sluggishly around 400rpm. I did not notice any off smells or leaks.
Please post your thoughts, helpful tips or suggestions, etc.
Thanks,
Jarol
whitetrasham Nov 13, 2010 07:27 AM
Bent pushrod or two?
pittman Nov 13, 2010 09:45 AM
Take the pushrods out and roll them on a flat surface to check them
mjcotroneo Nov 14, 2010 04:46 AM
reset your pcm first. might have just gone into limp mode to protect itself from you lol. seriously reset the pcm. see if it fixes it. if your not hearing any knocking or tapping there is no point in doing that first. you can remove both battery cables and hold them together for 3-10seconds and put back on. or you can turn the ignition to the on position with out turning the vehicle on and pull the pcm fuses then place them back in, turn off the ignition wait a few seconds and turn it completely on.
Joshiedoom Nov 14, 2010 05:05 AM
See what the codes are, check pushrods. In that order.
ramairetransam Nov 14, 2010 09:15 AM
how about some updates dude
R6cowboy Nov 15, 2010 12:26 PM
Checked the codes yesterday afternoon. We found out (via Snap-on PCM scanner) it was a MAF sensor code and 6 out of the 8 cylinders were missing. Towed the unit to the homestead and did a compression check where 4 cylinders showed no compression, 1 at 85, 1 at 130 and 2 at 155-160.
So the result of my hand to shifter miss calculation is a bunch of bent valves and push rods. And what does that equal folks? ... I have a nice winter project that's getting a new top end.
My 3 choices as of thus far:
-Cheap route= Fix back to stock and enjoy
-Little added performance= Add LS6 heads w/porting & polishing
-Add much more go-juice= examples: Trick Flow GenX top end kit, Ported & polished LS6 or AFR or Trick Flow heads & cam w/fair idle, etc and really enjoy
ramairetransam Nov 15, 2010 12:41 PM
Well I'm glad you found out what was wrong but sorry to hear it's gonna be expensive. Did you pull the heads or scope in the cylinder to see if the pistons it damaged.
mjcotroneo Nov 15, 2010 03:33 PM
oooo damn. wow. i bet you will never miss another shift again. lol. on the more serious side. the only to find out is to pull the heads off and hope you didnt do any damage to the pistons or the cylinders. might wanna pull the pan to check out bottom end. cheap side is probably gonna be around $2700 if you do the work for top end or 5k if you do build an engine on your own. expect it to cost more if you have someone else do it. so to hear about your misfortune. keep us updated on your boosted stroker build lol
SCM_Crash Nov 15, 2010 04:05 PM
Check your pistons too... May actually be easier to just pick up a take-out LS6 or LS2. I would pick up an LS2, put a LS6 cam and intake manifold on it, and call it a day.
Anthony Williams Nov 15, 2010 04:13 PM
Agreed, it took alot of surfing and calls but I found an new LS6 long block for $3245 including shipping, It's in my '99 Z28 now!
R6cowboy Nov 15, 2010 05:15 PM
Jacking up the valve train, I'm not all that worried and getting bent out of shape about. But if there's bottom end damage, I'm gonna have to choke a bitch, lol, because the car has 36,201 miles.
pittman Nov 15, 2010 06:19 PM
I hurt mine at 19,000 miles. Found a used block, added a stroker kit and afr heads\cam and been happy ever since. Went from 12.60 to 10.66 ET's.
Build it back better than before every time it breaks :D
SCM_Crash Nov 15, 2010 11:17 PM
With bent valves, it's very easy to imagine a damaged piston. That's why I suggested to check your pistons too...
Again, would be easier (and probably better) to just find an LS2 or LS6 to put in.
BTW, Mileage on the motor doesn't really matter. Mileage on the car itself does. Low miles cars feel more solid and ride better. They're usually quieter and have less electrical problems. But the LSx motors go forever as long as they're well maintained. Putting another motor in isn't the end of the world, and won't effect anything negatively.
R6cowboy Nov 16, 2010 12:05 AM
Thanks for the input. And indeed, inspecting the pistons is pretty much a given since the heads must come off. I'm just saying, it's going to be one heck of a bummer to replace an engine that was a perfectly fine 36k mile unit that still had much more life to it.
© 2026 MH Sub I, LLC dba Internet Brands
