Hi Temp wire with LIFETIME Warranty
$220
$220
$200
Fits 2005-Present GM LS2/LS7/LS3 Cars
Direct OEM replacement, exceeds OEM specifications, OBD-II computer
safe
0 Ohm resistance
Patented* design
Solid stainless connector cable with stainless snap lock spark plug
connectors, unique EMI/RMI protection ring
The only true solid stainless steel core wire that works with today’s
computer dependant engine and all race cars
No RFI / EMI issues – works with any fuel injection / No stereo noise
Increase power to the spark plug up to 400% over stock
Improves mileage and throttle response
High temperature silicone boots, 8MM jacket with fiberglass-reinforced
braid with fire sleeves resists temperatures up to 1200 degrees f
Ideal for use with aftermarket headers and turbocharger systems
Includes all necessary hardware
* Granatelli O ohm wires are patent protected by United States Patent number 7,185,622. This patent covers our unique method of producing ignition wires of extremely low resistance while maintaining very high noise suppression. The benefit of this invention is that full electrical energy from the ignition source is transmitted to the spark plug. The end result of the application of this method is increased horsepower, torque and fuel economy.
