c5/c6 spindle balljoint delete??
Anyone know where I can get a sleeve that presses into the balljoint hole, like in the picture?
Number 3 and 4. Is what I'm talking about.
I've never seen a sleeve pressed into the knuckle like that.
A factory knuckle just has a tapered hole at the bottom and a ball-joint pushed into the top.
Any info on where you got the screen shot or what your trying to accomplish by deleting the ball joint(s)?
Also the screen shot is a little different from any C5/6 knuckle I've seen, I don't see where the bottom bolt hole is for the wheel bearing, it seems like the bearing hole is lowered and there is an extra hole/bolt just below and inside of the caliper mount hole.
Here's a link to the spindles on Summit, you'd probably have to contact Speedtech to see if you can get just the bushings.
http://www.summitracing.com/parts/sd...eBYhoCFYnw_wcB
