Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
c5 gears
Old Oct 26, 2002 | 10:50 PM
fast blk y2k c5's Avatar
Default c5 gears
how can i tell if i have a 273 or 315 gear what are the code numbers and were can i find them i ran at the track and ran a best 1337 @ 105 if i do have a 273 what is the best et i can run bone stock
Old Oct 28, 2002 | 01:03 AM
Mitch's Avatar
Default Re: c5 gears
On the early C5s 97-98 look at the passenger side storage compartment lid, if you see G92 you have 3.15s if you don't see it you have 2.73s. On the later models you will find the build codes on the door of the glove box G92=3.15, if you don't see it you have 2.73s.
Old Oct 28, 2002 | 05:34 AM
06C6FVR's Avatar
GU2 is the code for the 2.73's...i know cuz i have them...
Daren
Old Oct 28, 2002 | 08:01 AM
Jason Haines @ LPE's Avatar
LS1Tech Sponsor
You can also tell by checking the rear end itself. On the passenger side (I think), the rear end will have a roughly 1" x 2" metal tag on it that says Getrag and then the rear end ratio.
