Would a broken passenger side output shaft keep the car form moving? I broke my driverside output shaft (I think). My car don't move when I put it in gear. If the output shaft was broken would the car be able to move? |
you need to give ALOT more detail about whats going on when you "try to move", is it a manual, does it make a grinding sound, does the driveline engage and engine rev in gear but car dosent move????ect..??? |
Originally Posted by Assassin you need to give ALOT more detail about whats going on |
Sounds like you either broke both or broke something internally. |
If you are talking about the output shaft in the gear box I dunno hard to say. I would think it would still move if it was just the gear box. I JUST got done rebuilding my car from something similar happening. When the rear goes you can row all you want through the gears with no problem. I busted my rear end casing all to hell when mine went. And normally when a shaft goes in the rear of our cars its the Left. Sounds to me like you may have broke more then just the shaft though. I would pull the gear box adn make sure you did not break the output shaft of the transmission. Mine did at the same time i destroyed my gear box. Its not that much labor to pull the rear end to see if that out put is on teh tranny is toast. I have my old rear pulled in the garage and looking at it and knowing that you have 2 shafts in the rear end the other should move, now if you did some major damage to the internals or somethign then no its not going anywhere. I would pull the gear box and look inside. Check your drivetrain for operation as well if you pull the rear and start the car and the output shaft in the tranny moves tehn its just your gears. Either way sounds like you need to give get it figured out then upgrade your shafts ;) |
probably also killed the transmission output shaft, if one of the rear end output shafts were in tact it should move, so its some mean rear end or transmission damage, your gonna have to pull the rear and see if the transmission is in good working order also |
Originally Posted by 00Vette I broke my driverside output shaft (I think). My car don't move when I put it in gear. If the output shaft was broken would the car be able to move? |
© 2024 MH Sub I, LLC dba Internet Brands
