LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Corvette Performance (https://ls1tech.com/forums/corvette-performance-27/)
-   -   getting LT's, but.. (https://ls1tech.com/forums/corvette-performance/468590-getting-lts-but.html)
SixPak Mar 13, 2006 10:10 AM
getting LT's, but..
I'm putting LG LT's with hi flo cats on the car, and was thinking of doing the G5X3 or 4 cam kit at the same time.
however, instead of the cam I'm wondering if doing a CAI and FAST intake might be a better option at this time, and save doing the cam when I can do the heads at the same time.
either way I go, the car will be getting a dyno tune at the same time.
I was hoping to put down around 400rwhp with one or the other setups.
is 400rwhp a realistic goal with just boltons?
opinions??
:cheers:
T-maxx Mar 13, 2006 02:31 PM
NO, do the cam along with the LT's and tune!! Even if you drive it for a year or so then do the heads new springs will be needed anyhow.
V-seriesTech Mar 13, 2006 02:55 PM
opinions??
:cheers:
Cold air, long tubes, cam.
WIth THAT cam, you'll have to go up to the 921 springs, New pushrods, etc.
Cam will make nice power man. I've seen 437 rwhp on an 02 Z06 with vararam, LG's and GHL catback and the GX series cam.
AintQik Mar 13, 2006 02:58 PM
400rwhp is cake with a cam and longtubes. I made 404 with a Cartek cam Kooks, and a tune. The FAST is a proven mod but I think it may benefit you more after a head swap. My C6 pulled like hell with heads/cam longtubes. If i had to choose headers and something it would be cam. If you need a set of pushrods and springs for the C6 I've got a set w/ 3000 miles on them. Save you a few hundred bucks. Either way, if you do a cam, do springs, pushrods.
The install isn't so bad if you plan on doing it yourself. Feel free to PM me if its something you plan on doing at home.
I don't agree with the cost of cold airs. I know they see gains on the street, but on the dyno I saw absolutely nothing with back to back pulls. Spend $400 someplace else on a C6. C5s are different stories.
flyinbird Mar 13, 2006 03:09 PM
friend of mine made 418rwhp with long tubes and the g5x3 cam on a 114 lsa, cam only set up, he was running bout a 11.6@118 yanking the front end off the ground bout a good 2-3 feet where as before the cam he couldnt, his car was a 2002 z28 should be about the same for you minus the yanking the wheels thing as vettes are harder to do that with :cry: I am sure you will be happier with that cam especially the first time your crank the car :)
P.S. if you are trying to decide between the g5x3 or four, just a little thing, he regretted not going with the g5x4 cam from the beginning, just if that might help
SixPak Mar 13, 2006 04:19 PM
thanks for the replies.
I was leaning towards the cam/springs/pushrods with the headers. prolly do the 160 stat also.
with what you've said, that's prolly what I'll do.
I've seen a CAI mod on the C6 that involves just turning the whole filter assembly 180* and cutting some holes in the shroud that makes for a pretty efficient CAI.
I'll have to do a little more research on it before I put the buzzsaw to my shroud tho.
:cheers:
Sigforty Mar 13, 2006 05:31 PM
Not quite a GX cam, but have the bolts ons plus a Futral F14 an made 423 rwhp.
© 2026 MH Sub I, LLC dba Internet Brands
