Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Electronic Throttle Control (ETC) ????
Old May 9, 2003 | 02:24 AM
BSMDan's Avatar
Default Electronic Throttle Control (ETC) ????
Need help. Working on a customers project car which he did on his own but now is running into problems. In his project he used a C5 LS1 with the harness and pcm. Then he wanted to change to the cable throttle body. So he replaced the harness and pcm and is now using an f-body harness and pcm. Unknown what happened to the original harness and pcm. Now he wants to switch back to the original ETC. Can we still use the f-body harness and pcm or do we have to buy a corvette harness and pcm? Can we keep the f-body harness, use a corvette pcm and add a wire for the ETC? If so, does anyone know the pin# on the corvette pcm?
Reason for asking is that we dont really want to purchase a helms vette manual due to the fact that most of our customers or f-body and mustang customers. We tried dealers but no luck and here in Hawaii, we havent found anyone who specializes in corvette pcms.
Can anyone help?
Thanks,
Dan
Old May 9, 2003 | 09:13 AM
kp's Avatar
kp
Default Re: Electronic Throttle Control (ETC) ????
The ETC is controlled by a seperate module on a C5 that is connected to the pcm through serial communication. In other words, it wont work with the f-body PCM
Old May 9, 2003 | 12:11 PM
BSMDan's Avatar
Okay, thanks alot. I'll let my customer know. More bucks.
Dan
