First time to the track thought it would be faster
So i took my car to the track for the first time and the fastest time i got was 13.05 at 107 my 60ft was 2.06 my car is a 02 ws6 with lt, ory, p&p throttle body, msd/ngk, gmmg, 3000 stall, and dyno tune it made 330rwhp and 326rwtq it was like 60 degrees out and my tires were set at 25 psi i launched it at 1200 everytime i launched it higher it spun pretty bad and i could only give it like 70% throttle out or it would spin. any advice on how to improve my times would be great thanks
mine dynoed at 294/287 and runs 12.20s ..........
do you have drag radials? with street tires go around the water and just do a little squeel to clean them off. Line up in the groove. when you pull up the the lights, stop when you prestage, then slowly bump into the stage beem, you will be farther back with more roll out. Im sure gears would help you with your stall too. I only have a 2800.
Yea i have street tires and i did a burnout everytime so your saying it would be better not to burn out? ill have to try and line up better in the groove yea i have a set of pro star 15x8 that i need to get tires for
