post your procharger times
Location: Home town Clive,IA current town FORT BENNING GEORGIA
hey guys im currently building a procharger set up for my car and im kind of curious to see what you guys are running. im actually building my car currently this time and starting in the rear and working my way forward hope to have the procharger kit ordered and installed by spring
10.33@136mph with a 1.61 60' has a lot more in it 10.1 or 10.0 but I was having clutch issues. Forged 347 stock heads about 14psi speed inc blower cam.
I am fairly set up for drag racing and have some weight reduction. Looking to loose more weight over the winter so I can make a 9.9 pass in some good air
My best so far is a 10.5 @ 132 on a 1.55 60' (spinning a little through 1st). Pulled a 1.45 60' but missed 3rd gear (just my luck). Been to the track 1 time since the re-tune. I know the mph will go close to the low 140s when I stop shortshifting 2nd and 3rd. I trapped 134 with 75rwhp less. Im wanting a 9 with the 6 speed before I decide to go auto. weights 3650 with me.
great minds think alike, what compression are you running? buy the end of summer im hoping to pull the motor and build a 347 using tsp product. they told me the lq9 72cc and a weisco -3cc piston should get me around 9.5to1 cr
yeah, i guess i've been told by a very good source that whole bs about prochargers making boost late is wrong. but ill be the judge and wait till i get mine
Im right at 9.5 to 1 with 317 ported heads and -2cc diamond pistons 6.125 scat rods....you should be right where you want to be bro! according to the guy where I ordered my kit from said he was just waiting on the balancer and pin kit, I cant wait!! I really like the supercharger sound
Here's mine. Switching to a SDCE setup and about 14 psi. More meth too.
https://ls1tech.com/forums/drag-raci...n-dragway.html
Ran the time in my sig. with the stock short block and heads. 9 psi with a D1-SC. M6 and a slipping Powergrip HD. http://www.youtube.com/watch?v=yPlhx00bx8o
im running a magnafuel 500 efi pump with a weldon boost reference regulator, no intercooler, blow thru, D1 on alcohol, hoping with a forged 12.5:1, 347ci on 10-15psi it will be able to run some low 9s or high 8s @ 3200lbs
