Going to the track on Friday.. Predictions??
Going to make it to Sac this weekend. I plan on mainly running 1/8 mile since there is no cage in the truck. If I see something good on the clocks, well, I will keep my foot in it. Here is the down low if you don't know.
Old times with the 347ci / 4L80E combo NA
60' - 1.603
1/8 ET - 7.249
1/8 MPH - 96.4
1/4 ET - 11.456
1/4 MPH - 118.672
That motor made 449rwhp with the converter locked and 402rwhp with it unlocked.
The new motor is a:
Pump gas friendly 11.14-1cr 418ci LS3 motor
AFR 225 heads
245/260 106/109 .646/.629 hydraulic roller
Super Victor intake
Dominator throttle boddy
This motor through the same drive train made 521rwhp with the converter locked and 469rwhp with it unlocked.
I recently swapped out the power hungry / heavy 4L80E for a built powerglide. Converter in the 80E was a 4,500, this one flashes to 5,200 on the trans brake.
Truck weighs aprox 3,400-3500 with me in it, has 4.56 gears and a 30" tall drag radial.
Passes will be NA only.
Any guesses?
60' - 1.603
1/8 ET - 7.249
1/8 MPH - 96.4
1/4 ET - 11.456
1/4 MPH - 118.672
The new motor is a:
AFR 225 heads
Super Victor intake
Any guesses?
No guess, but curious since i have a 404 with the same heads intake and tb. Smaller cam tho. How does your torque curve look. Ive been concerned since i see most ppl with the supervic loose alot unless the rev the **** out of it. What rpm was you peak hp at?
