10.1@143.7 on the bottle
Old 08-29-2011, 03:50 PM
baezi z06's Avatar
Default 10.1@143.7 on the bottle
Hi
NEW BEST 10.1@143
went two runs on the bottle
17°timing
added one degree to it, got better trap but worse start...
18°timing
The car is still a bit on the rich side, needs a bit of better tuning for closer AFR and maby bit more timing only 2nd time out on the bottle
Setup 2003 Vert
LS2 404ci
T56 MN6
3.42 gears
this was on ET street 26x11.5x16 slicks dot 13psi
200 shots
NKG 8´s plugs gapped .032
93 pump gas for motor
92mm plate kit
standalone cell (118okt fuel in it)
Also the car needs better traction/tires for that big of a shot , it´s spinning out of the hole 1st and bit in 2nd gear although i´m ramping the shot in....
i noticed that i´m running out of 4th gear getting close to rev limmit now!!!
So for the winter mods....
Full Cage ( i have 6pt roll bar already) and more savety things....
28 inch tires
better tuning then hopefully i´ll see high 9´s on the 200 jets before i´ll jet it more up....
thanks
Baezi
Old 08-29-2011, 04:48 PM
Larry @ AMS's Avatar
congrats.. very nice MPH
Old 08-29-2011, 11:26 PM
s346k's Avatar
damn that car is a top half monster.
Old 08-30-2011, 05:26 PM
Dirty Vegas's Avatar
I was thinking the same thing. It's running out the top end like a monster.
Old 08-30-2011, 10:41 PM
robsquikz28's Avatar
iceland to huh?
definitely a top end beast
Old 08-31-2011, 11:51 AM
baezi z06's Avatar
Originally Posted by robsquikz28
iceland to huh?
thanks guys.. .
the car pulls well yes... i´m shifting 3-4 on the 1/8 mile mark so the second half is only one gear no shifting pure power.... i love it.....
Baezi
Old 09-05-2011, 12:39 PM
WheelsUp84z's Avatar
what kind of DA do you see up there in Iceland? I thought mine was was all top end, i pick up 30-31 mph on the back half, then again i'm NA
Old 09-05-2011, 05:27 PM
baezi z06's Avatar
thanks guys...
1020hpa and huminity is 69-70%
i trapped same day 29mph NA
Baezi
Old 09-16-2011, 05:56 PM
97Z28SS's Avatar
Hey OP what front wheels and tires are those on your car, I need something that will clear 13" front brakes, thanks.
Old 09-17-2011, 11:07 AM
krazy4's Avatar
Look like GTO spares.
Nice times!
