made the 7's
Old Mar 11, 2012 | 02:16 PM
bigchief52780's Avatar
Default made the 7's
first run off trailer ran 7.924 @87.70 mph. backed that up with a 7.952 @86.67 mph. there is alot of room for improvement. would changing rear gears get me to 7.60s or 7.70s? what will a 150 shot of nitrous do?
Old Mar 11, 2012 | 04:05 PM
SEB's Avatar
SEB
I would go to a 4L60! I bet you drop 4 tenths there alone with a 4000 converter
Old Mar 12, 2012 | 08:48 AM
thunderstruck507's Avatar
What was the 60ft and what converter do you have?
Old Mar 19, 2012 | 10:34 PM
3000 bm holeshot. i think it was like 1.83 with a .7 reaction time.
Old Mar 19, 2012 | 10:55 PM
SuperSlow02's Avatar
What is the weight of the car? A better converter and lower rear gear would drastically improve your times. 150 hit should put you in the 6s. If your going to spray it, you'll have to take it into affect if you swapped anything. Honestly slap a kit on there and let er eat. That tall rear gear and tight converter migh do something cool on a hit. Now of you were more concerned with NA, you could step up to a 4400/5000 stall and a 3.7-4.11 gear.
Old Mar 20, 2012 | 05:58 AM
GtoSpd's Avatar
Swapping in a 4l60 would not help him. His TH350 is lighter and has less powertrain loss, and also has a much better ratio between 1st and 2nd gears (or it maybe 2nd to 3rd, can't remember right off). If anything, a 4l60 would slow him down.
Reaction time doesn't affect your ET. What tires are you on?
Congrats on getting into the 7s!
Old Mar 20, 2012 | 08:31 AM
DETROIT_AREA_00_SS's Avatar
FTi Stall....4200
Old Mar 26, 2012 | 07:17 PM
SPOOLED UP's Avatar
vids...
Old Apr 12, 2012 | 02:00 PM
switched to 3.73 and ran 7.88. i am going to try some 93 mix with 110 tonight and take all the extra stuff out the trunk. tires are 26x11.50x17. will try to get some videos.
Old Apr 21, 2012 | 07:55 AM
new time 7.66 @ 88mph 1.714 60ft on 93/110 fuel mix
