First track pass after year long build....how did i do ??
believe it or not there wasnt really any damage to the car....couple little dings in my true dual set up but thats all.
I ended up making 2 passes then after i got the new wheel studs in, however i didnt feel comfortable after all that so i ***** footed it down the track to a 13.93@110mph.
Heres some specs for anyone that cares
346ci motor 9.0:1 compression
243 heads
mahle -16cc pistons
torquer v2 112lsa cam
scat i beams
harland sharp rollers
made 400whp last weekend on the dyno
t56 trans
ls7 clutch/flywheel
moser 9" rear 4.11 gear full spool
moser 35spline axles with extended wheel studs
MWC tubular k member, upper/lower tubular arms
umi adjustable torque arm set at -2*
umi lower control arms
bmr adj. panhard bar
eibach pro kit springs
nitto 555s 315/35/17s
i think my biggest down fall was my stock rear shocks with 100k on them.
243 heads
mahle -16cc pistons
scat i beams
t56 trans
ls7 clutch/flywheel
oh yeah....wheels were torqued to 100ft lbs.
from what i am seeing online....it looks like this has happened to more then a few people.
time to upgrade to some ARP's and maybe even 5/8s studs
also have some SPOHN lower control arm relocation brackets that need welded on.
car is now on jack stands again.....removing my stock 100k mile shocks. Going to be welding on my Spohn LCA relocation brackets. Still deciding on what shocks/coilovers to purchase..........
I was wondering how long it would take for you to post this. I'll have to put the specs in the YouTube description, since your build thread was typed by a two finger typer. I actually found a decent bit of other vids with people shear one side but none doing both sides...
Looks like the right quarter was moving a lot but it didn't damage it? That's pretty crazy. Yikes, if it hops i always get out of it. No good times or runs will come from it. Glad you got it back up and running later in the day.
