New Personal Best 11.203 N/A 346ci.
Old 10-16-2012, 11:33 AM
tmartin01Z28's Avatar
Default New Personal Best 11.203 N/A 346ci.
Ran my new personal best this past weekend in indy. 11.203 @ 120.60 MPH with a 1.538 60' while running on stock rims in all 4 corners. I have a little bit more work to do this week and hopefully going back next week to Muncie to try and break 10's.
Attached Thumbnails New Personal Best 11.203 N/A 346ci.-1350315697333.jpg   New Personal Best 11.203 N/A 346ci.-lsx-shoot-out-1.jpg
Old 10-16-2012, 02:57 PM
Beave's Avatar
Very nice? What is the setup?
Old 10-16-2012, 05:15 PM
Full bolt ons, afr210 v2 heads, ported fast 102, nw 102 tb, yank 4000 stall, jph custom ground cam, yella terra rockers, 3.73 gears. It made 459 rwhp and 410 rwtq.
Old 10-17-2012, 01:32 PM
Beave's Avatar
Very nice. Im working on the suspension on mine before i go back. i think as long as i can get a 1.60 60ft i can go some .40's in mine and hopefully tap 120mph in the cooler air we have now since i ran last.
Old 10-17-2012, 02:02 PM
Zmg00camaross's Avatar
Nice. Full weight car?
Old 10-17-2012, 02:03 PM
85Iroc's Avatar
How much does it weigh?
LOL treed ^^^^^
Old 10-17-2012, 02:05 PM
LOL treed ^^^^^
Old 10-17-2012, 08:09 PM
GtoSpd's Avatar
Nice run OP! There's gotta be a 10.99 hiding in that car somewhere..
Old 10-17-2012, 08:17 PM
Old School Heavy
speedtigger's Avatar
Very strong pass. Good D/A?
Old 10-18-2012, 05:39 AM
The car is for the most part a full weight car. The only item that I changed out was the front bumbper support for a burkhart support. The suspension is stock in front and the typical BMR items in the rear. I have never actually weighed the car but i would guess with me in it 3500-3600lbs. As for the D/A when I made the run I am not sure what it was but will be keeping track of that from here on out.
Old 10-18-2012, 08:30 PM
GtoSpd's Avatar
Damn, thats a strong car. Figured you'd at least have the front sway bar dropped to pull off that 60', etc.
Old 10-18-2012, 09:12 PM
I forgot to mention that. The front sway bat was off
Old 10-18-2012, 09:15 PM
flintwrench69's Avatar
With a drag tire setup, skinnies up front no doubt. Without it I dont see the 60 foot time improving. 1.5 is not bad at all, nor is the 7.1 in the 1/8. Thats a damn good run with stock wheels on all 4. He didnt say if he removed the sway bar, that will make a difference. He did so it wont now lol!
Old 10-18-2012, 09:31 PM
I am shooting for that as well, would like to 1.5 the 60 as I have got 1.6s on a well prepped track. I got a PB a few weeks ago, 11.70 @ 119, 1.75 60 so our cars run about the same. I removed the front sway bar since & plan on putting some passes on all weekend.
Old 10-18-2012, 10:55 PM
Kent1's Avatar
Nice run and time! Put some skinnies and drag radials with light weight wheels and you will be in high 10's.
I am going to put heads and cam in my car soon. Then I will be headed toward your time!
Old 10-19-2012, 05:53 AM
Frost will be in town this weekend and will be taking a look at my shift points. I have been fighting with my 2-3 shift bouncing off the rev limiter. If we get this fixed I think I can hit 11.0-11.1's pretty easy next wednesday at RPM's track day. In your opinion what would be a better option. Tubular K member w/ tubular control arms, or a set of light weight rims?
Old 10-19-2012, 08:17 AM
Depends what you want to do with it. It's nice you have stock wheels on it so if you want to keep that look go with a k member and control arms.
Old 10-19-2012, 09:30 AM
Which direction (Drag rims, or K member etc.) would give me the biggest bang for the buck in your opinion?
Old 10-19-2012, 09:43 AM
Kinda debatable, with the wheels you drop rotating weight and if you put a good tire in the rear could drop your 60ft time. With the front end being lighter with k member and good adjustable shock should transfer weight thus improve 60ft times. Me I probly go with the wheels since it can help you and improve the look of the car also. Two birds one stone in my eyes.
Old 10-19-2012, 09:48 AM
Beave's Avatar
I agree, bigs and skinnies would no doubt pick you up the most and the car would look mean as hell.
Quick Reply: New Personal Best 11.203 N/A 346ci.
