Opening day new best in LS1 Chevelle
After a head gasket scare the previous night, this day was quite a relief. Was running 11.8:1 in 3rd gear, pulled it down to 12.8.
During the tuning run I smelled coolant and later found a huge puddle under the car. The car was previously tuned in 1st and 2nd on the street and I didn't realize this made 3rd gear so rich.
Found out the water leak which appeared to be coming from between the head and block was actually running down from a stripped coolant crossover bolt on top of the head. Put a longer bolt in it with some thread sealer and it was good to go.
Got to the track, unloaded my tools from the trunk, dropped the ET streets to 18# and as soon as they called lined up. Opening day so they had some nice prep down to get ready (but didn't prep anymore all day).
first pass was a new best: 1.71 60ft 7.42@94mph 1/8th and 11.67@115mph
Wideband was reading a little lean at 13.4 so I adjusted to tune to get it around 12.6 and next pass the car went 11.70@116mph on a 1.82 60ft (track was already getting slick)
My goal with the combo was 11.6s so it's nice to finally be where I wanted, but if it hooks again with the cleaner tune it might pick up just another hair.
Was shooting for the roll bar cutoff limit with the combo and I'm about there. Not going to put a bar or cage in a true street car. Depends how lenient the track owner will be how much further I will go with it.
Not in the near future. The guy who helped me clean them up now has all kinds of fancy toys like a flowbench, valve grinder, and a head machine (not sure what it's called but it does milling and other stuff)
Went back yesterday. We had much worse air (1300+ DA instead of 50).
Car went 1.69 60ft 7.42 1/8th and 11.68@115 anyway. Backed that up with a few low 11.7s.
Got a dyno graph of the car finally and it peaks much earlier than I expected. I should be able to back my shifts down a little and it might go faster (feels like it's nosing over the top of second at the track).
graph: (TORQUE IS NOT ACCURATE, rolled into the throttle because it kept trying to downshift)
From the looks of the graph and how it felt on the dyno I think it's nosing over at the top of 2nd on the track. I loaded a new tune which dropped the shift there 200rpm and tried a pass but the track was slick by then.
I don't know if it will pick up with the new shift point, but I don't expect it to hurt anything. It was commanded to shift at 6600 before and was hitting 6700ish during the shift, looks like cam peaks around 6300 and carries to 6500ish but the curve leading up to peak is flat enough I think it will fall back into the meat pretty good.
