LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Drag Racing Results (https://ls1tech.com/forums/drag-racing-results-85/)
-   -   Can't get this thing to hook.. (https://ls1tech.com/forums/drag-racing-results/1728962-cant-get-thing-hook.html)
crustysws6 May 31, 2014 02:28 PM
1 Attachment(s)
My 60' is killing me..Got 315/35 nitto's 373 gears 3600 Circle D...Blows tires off and bounces off rev limiter 1st gear.Not sure how to launch this to make 60' better..Attachment 453943
carolinaSS May 31, 2014 06:32 PM
Nitto's aren't the greatest at the strip. Did you try different air pressure and burnouts to see what they like best? Your car should have some 7.7s-7.8s in it with a good 60ft. Good luck
carolinaSS May 31, 2014 06:33 PM
in the 1/8, 12.0 in the 1/4
Jarred Hodges May 31, 2014 06:34 PM
I had 245/50/16 555r's on my car when it was just bolt ons. I had to do a ridiculous burnout to get them to hook. I went a 1.75 60ft on them. Also I had to launch right above idle, If I tried to stall it up it would blow the tires off everytime
crustysws6 Jun 1, 2014 11:59 AM
I didn't do a big burn out..18-20 psi.. I brought it up 1500 2000 on converter and nailed it. I haven't run much at the track. Thanks for you guys help. I will try them all and see how it goes next time. I know the big end is there but 60' sucks. lol
carolinaSS Jun 1, 2014 11:03 PM
I'd try to nail it off idle. You may have to get better tires.
thunderstruck507 Jun 2, 2014 09:18 AM
nitto street tires or 555r drag radials? there is a big difference between the 2
as posted above, flash it off idle...my car can dead hook that way but if you run it up on the converter like you did it doesn't shock the suspension as much and plant so it spins
if that still doesn't work, try not just stabbing throttle....roll into it quickly and it might grab
senicalj4579 Jun 2, 2014 09:22 AM
I would assume its the drag nittos? I would think he still wouldn't have a problem hooking with nitto drs considering hes not making a lot of power.
thunderstruck507 Jun 2, 2014 10:20 AM
You never know around here...hell half the time people say 555 they really mean 555R. Track could just be shit...I haven't hooked on my ET streets all year due to poor track conditions.
Get it to hook a 1.7 and you will run 11s with that MPH.
Krusty Jun 3, 2014 06:55 PM
They are drag radials. I will try flashing it from idle next time i go to the track or ease into the throttle off idle. I know its driving that is killing the time most likely. I was wondering how everyone else gets these cars off the line. Thanks for ideas.! I would love to go 11.99 if possible but might get close at least with practice. I couldn't get logged in for 2 days so i just made a different profile.:bang:
carolinaSS Jun 3, 2014 11:03 PM
I think the 11'a are possible, let us know what happens as you change things.
Krusty Jun 7, 2014 02:41 AM
Bigger burnout. Launch from an idle and roll on the throttle. Got This time... way better but I'm [IMG]timeslip june 12.17[/IMG]going to try it again next week. I think it will go 11.9!
Krusty Jun 7, 2014 02:44 AM
1 Attachment(s)
Attachment 455063
T6Rocket Jun 9, 2014 09:45 AM
That's quite the improvement, congrats!
If you decide to change to M/T or another DR, a 275/40-17 size is sufficient. The wider 315 size is not necessary.
Al
senicalj4579 Jun 9, 2014 10:03 AM
Much better. Yeah you don't need 315 size. IMO it will slow you down. Im still on 275 40 17 all around and my car has no issue hooking.
thunderstruck507 Jun 9, 2014 01:41 PM
Much better man!
If you didn't try it last time you might try one pass just nailing WOT off the line instead of rolling into it. Your car has the mph to go even better than 11.9, I could see it going 11.7 if the 60ft came down to 1.7s
Krusty Jun 9, 2014 10:42 PM
Thanks guys. I think i can get a 1.7 60' now. it was late or i would have went again. Hopefully i get time this weekend to go to the track.... If it goes into 11s i'm going to stoked as hell!
Krusty Jun 14, 2014 12:04 PM
Well ran 4 times this week 12.8 and three 12.5s ..60' is back to 2.0-2.2.. I tried flashing converter..Rolling into it...Bringing it up on Converter..All Spun soon as the pedal was to the floor..ughh..after last weeks 12.1 I thought I had it figured out.lol Maybe I'm getting tires too hot now?:burn:
Forcefed86 Jun 19, 2014 01:03 PM
Get some video from the side, front, and rear so we can see what it's doing. I'd try 15-16 psi too if you haven't. Heating up the tires too much just brings the oils to the surface and will make them slippery. Usually heating them up until they just start to smoke is plenty.
T6Rocket Jun 19, 2014 02:07 PM
Sounds like the track wasn't hooking.
Al
© 2026 MH Sub I, LLC dba Internet Brands
