aaaaand no improvement... sigh
So, it seems my times have gotten worse?
first time was 100% stock - 14.4738 @ 97.49 with a 2.3721 60'
tonight's best time was 14.555 @ 96.63 with a 2.3907 60' (street tires,LCA's+relo brackets)
...as you can tell i was instantly sad face
although i was spinning waaaay more in general. i tried with and without burnouts, running the car hotter vs cooler, rolling on the throttle vs flooring it, etc. i guess now i need some drag radials or slicks?
Tires would always be my first recommended mod. If the suspension is worn then it's always a good idea to replace the worn parts, but sticky tires and a stock suspension will hook better than good suspension parts and regular street tires. People have gotten good 60' times with street tires, but that's due to very good track prep (the kind that tries to pull your shoe off your foot when you walk on the starting line).
The slightly lower mph could be due to the slightly worse 60' or due to higher DA.
Throw some drag radials on it and give it another shot. Just to a burnout when you try the drag radials. Nitto 555R's would be a good choice because you could throw them on your stock wheels and drive to the track or even every day with them. If you want something even stickier than that and don't mind them wearing faster, I've had good luck with the Mickey Thompson's and I've heard good things about the Nitto NT05's. I believe the Hoosiers are very light and supposedly hook awesome, but they have all most no tread to start with.
Good job going out there and giving it hell! That's more than a lot of people will do
LS1Tech Premium Sponsor
Definitely get some tires and you will be much happier with your times. I bet you a set of drag radials alone would knock 5-6 tenths of a second off your times if not more. Also depending on where you have the relocation brackets the car may be hitting the tires too hard which is causing them to spin. What relocation brackets are you using and what hole do you have them mounted in?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
i'm using the Hotpart/J&M brackets in the lowest hole. i had read using the bottom hole would force the tires down more and give more traction, i guess they didn't mean on street tires lol
Since you are on street tires I would move the lower control arms up a hole in the relocation brackets and it should help out. The lower you mount the rear lower control in those relocation brackets the harder it will hit the tire due to the added positive anti-squat. There comes a point where you can hit the tires too hard and it will make the car more prone to spin.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
yea true, but now i need new tires anyway so i'll most likely be getting some nitto's of some sort. then if it still doesn't hook up at the track then i'll put 'em in the other hole. to be honest i just don't want to crawl under the car and mess with those bolts again. it was a pain in the butt, the back, and the neck lol. but i'll do what i gotta do to meet my goal
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Get a torque arm with pinion angle adjustment. Best suspension mod I did on my bolt on LT1 by far. 1.89 60's on 225/60 - 16 all season tires. The Nitto's are terrible on a car without a good suspension. I think you may be disappointed if that's what you buy...
lol just got the nt555r's! The street tires I was using were the same ones that came with the car when i bought it, i think the nitto's would be at least some improvement over those plus i needed new tires anyway. New times to come!
Throw those relo brackets in the trash if your car is not lowered. My car would bind and spin till I removed those.
https://ls1tech.com/forums/drag-raci...id-i-spin.html
