Took my GTO to the, N/A and Nitrous... Awhile ago I took my GTO to the track N/A. (my results here: https://ls1tech.com/forums/drag-raci...s-ago-gto.html) This time I went back with the only changes being a different tune, bigger injectors, bigger fuel pump, SD Tuned, and 15x8 drag wheels w/ 235/60/15 MT ET Streets @ 14 PSI for N/A. And for Nitrous i'm running a Nitrous Outlet 150 shot plate kit with an LNC-2000. I started off doing N/A runs. Didn't get much better than before and a lot of it was due to traction. Not sure if it was just the track or that Nitrous converter killing me. I couldn't get better than a 1.7 - 1.8 60fts N/A. I was hoping the 15" drag radials with more sidewall would help me hook up better but they didn't hook any better than my 18's did. I did get a PB N/A time though... 60'... 1.762 330... 5.066 1/8... 7.816 MPH... 88.97 1000... 10.204 1/4... 12.224 MPH... 111.20 After a few N/A runs I decided to spray her for the first time ever at the track. I know I had very little bottle left since my dyno session (https://ls1tech.com/forums/dynamomet...rous-runs.html) with 3 pulls and various testing in my garage. My bottle pressure was deep into the green almost in the red which I believe is 1200? My results... 60'... 1.665 330... 4.661 1/8... 7.167 MPH... 98.12 1000... 9.321 1/4... 11.143 MPH... 123.16 That run felt great! I didn't expect it to run that fast. Checked the bottle again. All I could get the pressure up was and it was around 925 ish. Decided to give it another shot figuring it wouldn't run near as fast. That time I ran a 11.4 @ 118 w/ a 1.6. It fell flat on its face on top end. I believe the bottle ran out 3/4 down the track. I know after that run I couldn't purge anymore nitrous out of the bottle. Nothing record breaking, but I'm happy with it. I'm hoping I can get into the 10s with some tweaking here and there. I think 275/50s will be needed and my line lock finally installed so I can do a better burnout for starters. I might even consider having my turn on point come on sooner than 3500 rpms since i'm launching out of the hole at 2500 rpms. Not sure what else yet. Here is my mod list for reference... -Vararam Cold Air Intake -MAF Deleted, SD Tuned -NGK BR7EF Plugs @ .032 gap -Comp Cams Ed Curtis LSX "Street Sweeper-XL" Camshaft (Actual Specs, Lift: 631"/612" Duration: 236*/240* LSA: 111+2) -OBX Long tube Headers 1-7/8" Primaries/3" collectors -OBX 3" Mandrel Bent Mid-pipes no Catalytic Converters -OBX 2.5" Mandrel Bent Cat-back -Deatsch Werks 50lbs (550cc) Fuel Injectors -Deatsch Werks 300c Fuel Pump (340 LPH) -Nitrous Outlet 90mm Plate System, “Wet Kit” (150 Shot -NOS Mini Progressive Nitrous Controller 15974 -Lingenfelter LNC-2000 Timing Controller -HP Tuners MVPI PRO tuned by Calibrated by Karger -RPM Level 7 Built Race Transmission 4L65E -Circle D SFI Certified Flex Plate w/ ARP Bolts -FTI 9.5" Torque Converter SRLS0086 (3700-3800 Stall). -Mickey Thompson ET Streets 235/60/15 Drag Wheels @ 14 psi. |
12 mph gain on a 150 shot sounds about right to me. Nice work |
Something isn't right. Only trapping 111mph on motor is a red flag. IMO. |
I just realized this is a cammed LS2. Yes 111 mph is very low n/a |
I've heard some people say it's low I've heard it's right. It is what it is, that's all I can say. Car has been gone through enough to chase an issue that isn't there. My opinion, it's the converter that does it. It's a nitrous/boost speced converter. Converters can make all the difference in the world. |
Very true about the converter. Regardless, I'm sure the car is a blast and a beast on spray |
© 2024 MH Sub I, LLC dba Internet Brands
