Farmington dragway Results New Best MPH
Car is a 02 Z28 A4
Engine Mods
Freshly Built Ls1 bored to 3.920
ls6 Block
Arp rod bolts
New Speed pro Flat top Pistons
Ls2 chain
Melling oil pump
FMS F14 low lift cam
799s Hand Ported by ZZRACER
Ls7 lifters
Vengeance Racing Ported fast 92
NW 92 throttle body
42lb green top injectors
Fast toys 98mm lid
Purolator Air Filter LOL
Tuned by JonCR96z
Exhaust
Jett hot long tubes into LLP y pipe into a Magnaflow bullet that stops at rear end
Transmission Mods
Built 4L60E by IH8FORD
FTI 4K hard hit stall
Big Derale Cooler
Stock rear with 342s
Suspension
Bilstein shocks
BMR springs lowerd 1.25 inches
Spohn ADJ LCAs
Spohn ADJ Pan hard bar
Spohn adj torque arm
Engine Mods
ls6 Block
Arp rod bolts
Ls2 chain
Melling oil pump
Ls7 lifters
NW 92 throttle body
Fast toys 98mm lid
Tuned by JonCR96z
Exhaust
Transmission Mods
Big Derale Cooler
Suspension
Bilstein shocks
Spohn ADJ LCAs
1.56 60' on stock 10 bolt and 3:42s is no joke. Good job guys. That stall and all that torque must feel pretty good coming out of the hole. Roll up that damn window Mike lol
Stock ls2 bottom end, ported 799s, ported fast 102, 236/242 cam,full bolt ons. My car is heavier than Mikes but makes more power. I have a looser converter ,8.8 rear with 3.08 gears. 3520lbs race weight. Mikes car is 34?? Race weight,he is a little lighter(he's a little guy)
Car been on a dyno? I would be interested in seeing the dyno graph and transmission settings. You wouldnt beleive how many local peoples trans tunes ive toyed with and dropped a little here and there with adjustments. Dont know what part of NC you in but holler if you ever decide to run at Shadyside!
I've had it on the dyno but I had bias ply tires on it and it didn't get a accurate reading with those tires.
I really want to re dyno it on regular radials. I'm guessing 440 rwhp 400 or 410 tq
With those bias plys we added 8 psi of air in them and gained 25 rwhp for a final pull of 425 whp and 400tq.
I got notified it's not good to dyno on Bias plys. Didn't know before hand. Obviously they give you a low reading and can blow out
