Stock 2002 B4C 1/4 mile
Just took my 02 B4c out to beach bend drag strip. Its stock with a deleted muffler .Good news is it ran a 13.290 @104.5 ,bad news is i think ill need a new trans soon as it hit the rev limiter a bit coming out of 2nd gear .
heres the video . https://www.youtube.com/watch?v=ynuu...ature=youtu.be
yea that was me . I let off to see it it would switch to 3rd and it refused to change at all because of that . I ran like a ******* 13.8 in that pass . awful pass for both of us .
I may have worded my post poorly but I'm saying you want your 4l60e overfilled a bit. Overfill it about 1/4 in. over the full line as opposed to in-between the full and low line on the dipstick.
Overfilling by half a court to a full quart prevents fluid starvation to the 3-4 clutch pack at wot in the 4l60e.
Yes on the overfill slightly.
the other thing that may be affecting you and I cant properly describe the mechanics of it is to leave in overdrive and let the car shift itself, manually shifting it sends additional fluid somewhere causing a lack of fluid where you need it. Hopefully someone with a better grasp on the specifics sees this and can give a better explanation.
When in D3 the over run clutches are only applied during the 2-3 shift when fluid is critical for the 3-4 clutch pack.
Problem can be solved by adding the sonnax 2-3 shift valve which when D3 is selected it will keep the overrun clutches on 1-3 and won't rob anything during the 2-3 shift.
With the sonnax 2-3 shift valve keeping the over runs on when in D3 threw all gears it also helps support the forward sprag assembly.
Surprised that overfilling anything is good.
On my Fords, if the trans is over the line at all, I will find a bubble or two on the stick when it's really hot. Bubbles = foaming, which is not good for trans fluid.
Al
Al
Thanks man. I have no plans of matching your cars power,but would like to match the looks
going this weekend to get new trans
Rebuilt trans - 0 miles (have receipt)
upgraded sunshell,
Upgraded valve body
Extended 2-4 band
Hi performance 2-4 servo
Ray besto stage 1 clutches
.500 boost valve
Shift kit
precision industries vigilante converter
3000 stall
upgraded sunshell,
Upgraded valve body
Extended 2-4 band
.500 boost valve
Shift kit
3000 stall
