On3 kit/Cast 78mm Track results
Old 12-04-2017, 10:43 AM
soloman369's Avatar
Default On3 kit/Cast 78mm Track results
Thought is share my track results form my weekend at SCT Dallas
Set up
Lq9 block stock ls3 internals
Craigslist 799 P&P heads
Tick stage 2 ls2 turbo cam
Fast 90/90
On3 non ac turbo kit
On3 Cast 78mm turbo
Precision 46mm gate
4in intercooler
HPI 95lb injectors
Dual Racetonix 340 pumps 1 on a Hobbs
P59 pcm with flex
Pass was on E75
Th400 non trans break
Yank 3600 Eliminator series stall
Strange 12 bolt Detroit locker/3.73s
Rear tires were MT pro bracket radials 28-10.5
Stock rear swaybar
Stock fuel lines
Race weight was 3700#
All passes were on the foot brake leaving on no boost @75kpa and also on gate pressure witch is 11# in the log
1st dig pass ever on the set up
2nd pass of the night when my 10.0 class started
3rd pass on the car
Old 12-04-2017, 07:19 PM
Sladester2's Avatar
Nice runs
Old 12-06-2017, 05:58 PM
Doug G's Avatar
Congrats
Old 12-10-2017, 08:00 PM
assasinator's Avatar
man i like those runs.
Old 12-11-2017, 12:15 PM
soloman369's Avatar
Thanks guys!
Plan is to swap rear gears here soon and turn it up! I am already running out of gear faster than I thought.
Also get some front strange coil overs I just have stock bilsteins on a pro kit right now and get and ARB.
Old 12-12-2017, 03:46 PM
MY_2K_Z's Avatar
What gears are you going to? I have 3.55s seems like it would be a good fit for you as well.
Old 12-12-2017, 08:37 PM
soloman369's Avatar
I'm thinking 3.42.
Quick Reply: On3 kit/Cast 78mm Track results
