Cam/Stall/Gears Results... Confused
Old 02-23-2018, 11:59 PM
97TAsom's Avatar
Default Cam/Stall/Gears Results... Confused
I went to Huntsville Dragstrip tonight and my previous best 1/8th mile was 7.8X at 88.XX with a 1.77 60' I believe. Tonight I managed a 7.68 at 89mph with a 1.66 60'. I feel like this isn't right... I went from running a 7.8 with a 3600 PTC converter with stock cam and 3.23 gears on NT05 tires. I now have a Tsunami cam with a yank PAS3800 and 3.73 gears. I have MT ET street SS's and LCA relocations coming in the mail this week, but I feel like I should have a higher MPH and lower ET than that, even with the NT555s I'm currently on. My shift points are at around 6300, would bumping them up to 6700-6800 help get that ET down and MPH up? It's kinda disappointing to only drop .1-.2 and pick up 1mph after this big of a cam swap and swapping gears... Here is the dyno sheet
Old 02-24-2018, 12:12 AM
98CayenneT/A's Avatar
You definitely need to be spinning it higher than 6300 !
That also is a tighter converter for boost and nitrous so you probably are not seeing the shift extensions you would with a n/a converter.
Your shift extensions are probably around 5,000 rpms, maybe, where you are only making about 310 whp.
Spin it to 6800
Old 02-24-2018, 07:20 AM
HCI2000SS's Avatar
As mentioned above definitely spin it higher. Weather it's a stick or auto, a cammed LS1 needs to rev.
Old 02-24-2018, 09:13 AM
Jtm2085's Avatar
Tight converter, low shift points and big cam... I am not far from you, do you ever run at lassiter, steele or holiday beach?
Old 02-24-2018, 10:39 AM
97TAsom's Avatar
Spin it to 6800
I'm going to have Lane crank up the shift points. It should be trapping so much higher.
Old 02-24-2018, 10:40 AM
97TAsom's Avatar
I've ran at Lassiter and Steele, never heard on holiday beach
Old 02-24-2018, 10:42 AM
97TAsom's Avatar
Yes it does and I can tell this cam wants to rev high.
Old 02-24-2018, 10:55 AM
97TAsom's Avatar
FWIW, when it shifts at 6300ish, my RPMs drop top around 54-5500. So looking at my graph, I should be making 350+whp the whole time after I leave the line.
Old 02-24-2018, 03:17 PM
marc97taws6's Avatar
As others have stated, should be 6700+ shift points and not a great converter for the setup!
Old 02-24-2018, 03:19 PM
97TAsom's Avatar
Right, I knew the converter wasn't ideal for a N/A application but I thought it should still pick it up quite a bit. I'm just waiting to get this nitrous kit ordered, then I believe I should be able to run high 6's to 7.0's on a 100-150 shot
Old 02-24-2018, 03:21 PM
Nitrous will definitely make that a very fun street car!
Old 02-24-2018, 03:22 PM
97TAsom's Avatar
That's the plan! But it'll still be N/A....
Old 02-25-2018, 05:35 PM
bjamick's Avatar
You’re not far from me, you definitely need to up the shift points. That’ll pick it up definitely.
Old 02-25-2018, 05:36 PM
97TAsom's Avatar
I am, I'm going to move them to 6800
