00' 6spd Z28 228/230 Jegs Cam Bolt on 1/4 mile Just to get away for a night, I went out to Royal Purple Raceway to make some passes. Royal Purple fills with complete dipshits about 9:30-10:00 so I only made three passes and then rolled out. https://cimg1.ibsrv.net/gimg/ls1tech...c2ac237aab.jpg The car is full weight with a 10" sub and amp. 3440lbs. I weighed it on the way home on a CAT scale. The rear is a Pyle Brothers built 9" with a Strange 3.90:1 posi and Moser axles.:barf: The rest is simple bolt ons that we got here and there. I apologize to all the guys that are going to start in on the "you could be faster if", but it is what it is. https://cimg6.ibsrv.net/gimg/ls1tech...8dcc9eaa59.jpg |
Nice looking car you have there. |
Thanks. It just seems to stick with me for some reason. It is where I got started in the LS think. |
What was the DA? |
I didn't look. Usually I try to but what you get off the interwebs isn't usually very accurate and I did not have a weather station. I was really there just to bang some gears. |
Ok. I have the same cam on 112 lsa and self ported 799s. Hoping to trap 120-121 at 3300lb rw, but saw low mph and was curious about the DA. |
Stock 4l60 or t56?? |
Originally Posted by HCI2000SS
(Post 19866981)
Stock 4l60 trans? Cody do you have a pic of the car from the back of the car? I want to see that spoiler. |
28" tire? |
Yep I see 6-speed in the title now. Missed it before. MPH is a bit low no doubt, but if conditions were bad that could explain a good bit of it |
Always good to take some time and hit the track for a mini vacation. You got better 60' every pass. Keep going man. Don't pay attention to the lights just focus on good launch and hit your shifts. Goodluck |
Originally Posted by Tuskyz28
(Post 19866986)
He said 6 speed.... Cody do you have a pic of the car from the back of the car? I want to see that spoiler. |
(Post 19866992)
Originally Posted by sxc Z28
(Post 19867003)
Originally Posted by codyvette
(Post 19866742)
Just to get away for a night, I went out to Royal Purple Raceway to make some passes. Royal Purple fills with complete dipshits about 9:30-10:00 so I only made three passes and then rolled out. https://cimg1.ibsrv.net/gimg/ls1tech...c2ac237aab.jpg The car is full weight with a 10" sub and amp. 3440lbs. I weighed it on the way home on a CAT scale. The rear is a Pyle Brothers built 9" with a Strange 3.90:1 posi and Moser axles.:barf: The rest is simple bolt ons that we got here and there. I apologize to all the guys that are going to start in on the "you could be faster if", but it is what it is. I see you don't like the 9" rear. May I ask why? https://cimg6.ibsrv.net/gimg/ls1tech...8dcc9eaa59.jpg |
Is the front sway bar still on the car? is the spare tire and Jack still in the car ? |
The 9" is fine. I have had several of them in several applications. The Moser axles suck. The register isn't long enough to engage the wheel hub. The sway bar is gone. The jack and tire are there. |
get that 60" and u be rolling. hit those shifts and be in 11's. |
Hey Cody, You mentioned a CAT scale is this at the track? I'd like to know what my car weighs after the mods. I too could shed a few pounds these cars aren't the easiest to climb in and out of anymore. |
There is a scale at Royal Purple but it was jacked up. There are Cat certified scales at almost all Loves stations it is $11 to weigh whatever you want and it's open 24/7. I weighed just about everything I have from my haul trailer to my 1/2 ton daily. |
© 2024 MH Sub I, LLC dba Internet Brands
