Notices
Drag Racing Results Track Times | Records | Testing Info
†Timeslip Database CLICK HERE
Critique my cars launch
Old 09-10-2018, 01:46 PM
ragtopz28's Avatar
Thumbs up
Much better than before (first vid in post #1). Notice tire/fender gap doesn't decrease or increase. Some say that is what you want. I personally like to see a slight rise in the rear.
It is not spinning too bad and it is definitely not unloading the tires. Maybe 1 click at a time looser and see what it does
ragtopz28 is offline
Old 09-10-2018, 05:47 PM
Doug G's Avatar
Agree....WAY better.
On the hit you can see a quick tire to fender separation for just a split second.
Dial it in to make the gap stay out for 10-20 feet, you're golden.
Doug G is offline
Old 09-11-2018, 05:46 AM
Romulus22's Avatar
Thanks guys. When I was under the car installing the shocks. I was looking at the cars lower arms and noticed they are about level with the ground. Do you think it would also help to bring the rear down a .5”-1”? I raised the front after the car was initially built because it destroyed the stock mounts and 1 control arm from wheel hop. I think I can modify the rears somewhat easily enough but if it isn’t needed I’ll hold off because I plan to go ladder bar on my new setup when that happens.
Romulus22 is offline
Old 09-11-2018, 06:13 AM
AINT SKEERED's Avatar
A slight angle up wont hurt. Lower rear of arm some.
AINT SKEERED is offline
Old 09-11-2018, 08:22 AM
ragtopz28's Avatar
^^"but it helps....it does help"
Old 09-12-2018, 08:01 PM
Romulus22's Avatar
this is as far as I can go on the stock part. It would probably be plenty strong enough as is. But I think I’m going to add some material to the bottoms that go back to the spring bucket. And have further room to adjust in the future until I switch my setup.
Old 09-12-2018, 08:35 PM
Looks to still point down in front.
Old 09-12-2018, 09:25 PM
Romulus22's Avatar
The rear is on jack stands
Old 09-13-2018, 06:46 PM
Romulus22's Avatar
Leaving one tire on and lowering the rear to ride height I now have a .75” rise from back to front on an 18.25” control arm. I hope this helps in my goal for a better 60’.
Old 09-13-2018, 09:54 PM
It will help. It certainly helps
Old 09-29-2018, 08:26 AM
Romulus22's Avatar
Had a chance to run the car last night. I bumped the tires back down to 10psi, shocks at 3 clicks from full hard on the compression and 3 clicks from full loose on rebound. First two runs the two step was at 4K. I bumped it back up to 4.4k on the last two runs. Iíve definitely improved the 60í a little but did not improve on the overall 1/4. Either way itís a consistent 10.4 car now.
Old 10-05-2018, 08:49 AM
  #32
Great runs, congrats!
Al
T6Rocket is offline
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
