i HAVENT POSTED ON HERE FOR YEARS BUT...
1950 GMC body, 1991 S-10 chassis, 408 w/ afr 225's, BTR cam and 102 LSXRT - .T56 w/ monster clutch, 8.8 rear with 4.88 gears on 275/40/20 drag radials. 20 x 8.5 wheels on all 4 corners.
Sleeper mode engaged. 1.59 60ft on 20's with a clutch........
I was on the 7000 RPM rev limiter about 100 feet short of the stripe but I'm still quite happy.
The following users liked this post:
jason99frc (11-21-2022)
low2001gmc (11-22-2022)
MASS seller approved
I did back like in 2009-10. I would have trouble starting it. Had to crank it like 5-6 times before I could get it started, then had to rev it to keep it on, then stall at about every stop stop sign or light. Had to try to yield only on stop signs and try to catch green lights. After about 6 mm months, just got fed up, removed and sold. It's been years since, and since I keep seeing them around, get curious if Fast ever fixed or their issues or same is why I asked. I guess not. And yes wide open and part open throttle response was awesome. AGAIN, SWEET LOOKING TRUCK. LOVE IT.
This sucks...... I had a perfectly running holley sniper 102mm that looked so perfect on the truck but I started chasing power and bought the FAST, I gained 3 hp at peak but did gain 30+ in the midrange, in hind sight I should have left it alone with the sniper. Might be time for another intake swap.
