First Win , New best in the heat...
Evadale Raceway in Evadale Texas had another one of their Match Race Madness races last night..I was paired against a local of mine from DeRidder and won the race against him..Pocketed $150.00 for one run which more then paid for our night out..Here's a LINK to the race site..
My car ran the best so far this summer with a 11.35 @ 118..The DA was at +2890 and hot *92..Humidity as at 56% but the track was hooking pretty good..I made 5 passes and my 60's never varied more then 3 1/100's..Was able to finally get some consistency out of the new Turbo 400 leaving off the brake using my delay box..
On the match race run I took a couple hundred's out of the box since the sun had set and went .497 red against his deep staged .437 red..I should've left the box alone since this was my first night race of the year..If I had left it where I had ran during the day it would've been a low .50 light..Here is a shot of the car that the track photographer took...
Thanks Frank..Since switching over to the Turbo 400 the car has been really consistant and is fun to race again..The 4L60E just was starting to be a pain in the *** to figure out..
Hopefully this year I'll be able to go rounds at the Shootout this fall without something going wrong...
I am one of the lucky ones. I've had good luck with the 4l60e. I run low 1.50's 60fts in the summer and have been 1.47 in the cold and have never had any problems. The transmission I currently have is 6 yrs old(GM remaned) and I have a spare that had 4yrs on it that was working great when I changed it. I did buy a TurboAction Turbo350(from on of the stocker boys) with the reverse manual valvebody that i will put in only when i have trouble with my current setup. Good luck and keep us posted. Frank95z
Originally Posted by JaSSoN
What were your 60' times if you dont mind Tim. Did they fall off from the 4l60e?
I'm fixing to pick Madman mind to try and get this thing to 60' a little better..
Originally Posted by SMOKIN01TA
congrats tim, good to see you getting the car running right
Thanks Rodney ! Still working on getting the car to leave better but its getting there..
Originally Posted by swapped2ls1
Congrats on the win Tim. Glad to see the car is running so well. I can't wait to see how that thing runs when we get some good air later in the year!!!!
John
John
Originally Posted by Coach 02 A3 Z/28
What delay box are you using?
Coach
Coach
Coach I'm using a Meziere box..I don't know if they even still make them anymore through Meziere..Its a single delay that I've used in a couple of cars in the past..I'm a top bulb leaver and it works great..
I wasn't sure if you ran no box only but I wouldn't run brackets without it..
Thanks
