1.65 sixty foot on 16 in e.t. streets. (m6)
How much more is left? This is naturally aspirated as well. I am going to try and remove some weight, and relocate the battery to the rear. I want to be more consistent with my 60'.
I have a full weight car that weighs 3700lbs . with 4.30 gears I leave at 6000 on 26x11.5x16 et streets and the best on them is a 1.63. I switched to 255x50x16 m/t drag radials and have pulled a 1.59 and several 1.62 60 ft's . \
Now in the summer time, I feel the drag radials need less burnout as I dropped back to 1.7's and 1.8's with a greasy looking tire from the burnouts.
After the clutch is broke in I will be trying them again to do less burnout and try to go low 1.6's in the heat.
I have pulled a couple of 1.56-1.59 60ft. Thats was with a full weight car with stock shocks and springs and the front sway bar links disconnected and a BMR Torque arm. A set of drag shocks would get me a better 60ft. You should be able to copy my set up. For the most part I'm all stock right now.That was also on 26" E.T streets. A set of 28" tires would really help. My sig is a 1.62 60ft. that was with a stock clutch and sway bar hooked up and stock torque arm. You have room for improvement
