What's wrong with this slip? Went to the track last night. :( here's my best time 60'...2.556 330'...6.157 1/8...9.018 mph...86.21 1000...11.447 1/4...13.479 mph...110.49 How do you guys cut 1.9-2.0 sec 60' times on street tires? :confused: |
a4 or m6? |
Originally Posted by kyles2000z a4 or m6? |
seems like you're spinning alot.....you just gotta find that sweet spot where the car doesn't bog off the line too bad w/ least spin ass possible. i can only manage 2.15s on my street ties. that's launching at 3k. dont completely dump the clutch, just feather it untill ya feel you're hooked well enough to nail it. |
btw what are your mods? |
Originally Posted by kyles2000z btw what are your mods? |
Try launching at idle. Then start working your way up from there. |
with those mods you shoul be deep into the 8's in the 1/8 and deep into the 12's, dont know whats goin on |
It's pretty obvious that your launching is killing your ET. With street tires, what works for me (consistantly cutting 1.9x) is to raise the rpm to ~3,500 rpm and make sure clutch is eased to a point it is almost engaged while waiting for the lights, and then let out the clutch slowly (feathering it) while keeping at the rpm and once tires gets bit of grip, I go wide open throttle. |
Originally Posted by 01SSDRVR Went to the track last night. :( here's my best time 60'...2.556 330'...6.157 1/8...9.018 mph...86.21 1000...11.447 1/4...13.479 mph...110.49 How do you guys cut 1.9-2.0 sec 60' times on street tires? :confused: A) have suspension mods, like drag springs; B) have gears, like 3.73's or 4.10's; C) are b'sing to their hearts content; D) have sick track prep on the day, and think it is the norm; E) All of the above. My best thus far is a putrid 2.2 sec. 60' on street tires, and that was frying the clutch off the line (Slipped it a grip). You shouldn't be cutting 2.5 sec. 60' times though. Don't over bog or spin the crap out of your tires off the line. Your car should run mid to high 12's from what i'm seeing. By some BFG DR's and line lock. Provided you don't blow up the rearend, I guarantee you won't spin the car off the line, cause I sure as fuck can't. |
try the old 2000 rpm's dump then floor it method you will cherp the tires the bog sould be good for a 2.0-2.2 60" get a little better can get 1.9 out of it. I HATE slipping the clutch |
Originally Posted by Denom My theory is that the dudes that claim 1.8 and 1.9 sec. 60' times either: A) have suspension mods, like drag springs; B) have gears, like 3.73's or 4.10's; C) are b'sing to their hearts content; D) have sick track prep on the day, and think it is the norm; E) All of the above. good. 2.0 60's are routine for a good driver. Unfortunately, all of your woes are due to driver error. You'd run a 12.6 - 12.7 or so on a 1.8 short time. You should be trapping higher as well given your mods. |
Originally Posted by unit213 That absolutely is not the case. A 1.9 60' on stock rubber is very good. 2.0 60's are routine for a good driver. Unfortunately, all of your woes are due to driver error. You'd run a 12.6 - 12.7 or so on a 1.8 short time. You should be trapping higher as well given your mods. Dunno, been to California Speedway and LACR a busload of times (well over 10), and I don't see people cutting 1.8-1.9 sec. 60' times on street tires (meaning not drag radials or slicks). I make it a habit of asking people what they ran, and what mods they have, especially since I usually only average 3-4 runs at Speedway in 8 hours. Experience has shown to me 1.8-1.9 sec. 60' doesn't happen at the track I go to with F Bodies on street tires. I'm sure E Town or some other sick track with EXTREMELY good track prep would make it possible for such times, but I have yet to see it. |
Originally Posted by unit213 That absolutely is not the case. A 1.9 60' on stock rubber is very good. 2.0 60's are routine for a good driver. Unfortunately, all of your woes are due to driver error. You'd run a 12.6 - 12.7 or so on a 1.8 short time. You should be trapping higher as well given your mods. I have pulled several 1.9ish 60fts on street tires. 2.0s are all day long, just a routine :) |
Originally Posted by unit213 Unfortunately, all of your woes are due to driver error. You'd run a 12.6 - 12.7 or so on a 1.8 short time. You should be trapping higher as well given your mods. |
If you're cutting 2.5 60's, then I must assume that you're not powershifting either. You're losing 3/4 of a second in the first 60 feet. If you're not powershifting, you're losing almost a total of 1 second in the 1/4 mile. Honestly...it's driver errror based on your slip. No offense meant of course. :cool: |
Originally Posted by unit213 If you're cutting 2.5 60's, then I must assume that you're not powershifting either. You're losing 3/4 of a second in the first 60 feet. If you're not powershifting, you're losing almost a total of 1 second in the 1/4 mile. Honestly...it's driver errror based on your slip. No offense meant of course. :cool: |
What kind street tires do you have and what air pressure did you run them at you might also what to get a decent tune for the car. |
Originally Posted by 11SECSS What kind street tires do you have and what air pressure did you run them at you might also what to get a decent tune for the car. |
Originally Posted by 01SSDRVR The tires were yokohama avs es100. I had the tire pressure at 36 psi. I plan on getting the crane/vinci handheld tuner this week. What kind of suspension mods would you guys recomend to help me hook up? |
| All times are GMT -5. The time now is 12:20 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
