help with 60'
Old Jan 22, 2006 | 09:46 PM
dave70's Avatar
Default help with 60'
looking to see what kind of times i should be getting i can't get em under 2sec. best 1360' to date is 13.40's the mods in sig now i have 4.10's and gfg dr's will try to roll out slowly to save 10 bolt any sugestions on tire psi and burnout time? what can i expect to run?i know my times are on the slow side but i'm still trying to get use to the m6 only raced auto's b4 thanks for any info?
Old Jan 24, 2006 | 01:22 PM
HPA BILL's Avatar
when you do your burn out stay away from the water. i usually ran my dr at around 21psi. you want to do a decent burn out. roll out of the burn out then do a couple little dry hops and clean the tires off. then when you launch leave at idle or a little above. i was cutting low 1.6's and a few 1.5's with this. good luck to ya!
Old Jan 29, 2006 | 07:07 PM
RGR Pete's Avatar
1320=1/4 mile
A long burnout is not needed with Dr's, my best 60ft is with a short clean off. I like 18-20psi, track prep plays a factor and watch out for guys with street in front of you. Street tires leave water at the line.
