WTF i went backwards!!!!
Well i have a 99 SS a4 with a 3600vig stall, 224trcam, ls6 intake, ported tbody, 3.73 gears and ported stock casting heads milled .015. Well my car tuned on a mustang dyno put down 366rwhp and 342rwtq. Last night i pulled my best 60ft 1.71 and best mph 114.65 but same old time of 12.2. When i was 224 cam, 2800 midwest stall and stock gears i ran the same time. I only gained 1mph and droped .1 on my 60ft. WFT happend here. On my old setup i ran a best 12.05@113, 3 times. My car has been retuned since the swap on parts and gained almost 30hp. SO what happend here. I was realy hoping to go 11,s. I would think with gears, intakes, stall, heads, and tune i could et at least .3. any ideas??
Originally Posted by daniel6718
heat? its hot this summer in tx and aint expecting to run alot better than i did with less mods in the winter....
Sounds like something is pretty bass ackwards. Weve done a few small cam setups with LS1 intake/stock heads/tight verters that went 11s first time out. What heads are they? Put the stockers back on, maybe change the cam and sorted out should go pretty easy 11s
On our Mustang dyno 365 hp in an auto normally runs 11.6s-11.9s Id have to guestimate
