In desperate need of some suspension help
My setup with the suspension is as follows
SA Qa1's 90/10's ont he fron
Tranny mount adj tq arm set to -2
Strange rear shocks 10 way adjstable
25 mm sway bar
28*10.5S Hooiser Slicks
!front sway bar
Solid rod end LCA's w Reloc brackets
12 botl 4.56 G5X4 full bolt on M6 car made 429/386
RW 3576
I cant get this car to hook for my life. Everything thing i try results in high 1.6's low 1.7's
I have the rears set on 7 and the fronts set on 3. I am leaving without the 2 step at 6k with the 2 step i got the car down to 4600 rpm and was still spinning big time on the launch. I am running 12 psi in the slicks and 40 psi up front. The relocation brackets i ve tried in the 2nd and 3rd hole and still this hasnt helped. Anyone haev any suggestions or a good starting point to try. I messed with the front setting a little but (tightening them up and looseiong them) netted worse 60's times.
:help:
25 mm sway bar
!front sway bar
RW 3576
:help:
Probably have a clutch that does not slip at all in it don't ya. I have the same issues
with my spec 3 , you can't slip it so it just acts like a burnout on the launch. There is
a reason all the superstock and stock class stick racers use Mcloed soft locks , they don't hit the tires like a sledgehammer.
