cant get 12s?
2.2 or a little better, even my best launches are 13's, but my top end seems to go so slow like right before i shift it lags, and as soon as i hit the clutch i can still hear all the exhaust pushing hard
unless you do some crasy 6k clutch dumps your 10 bolt will be fine on the nittos...they dont hook that good anyway...
and id most definatly ditch the stock y pipe or what's left of it
Look if you drag race, you are going to break something!!!
Biggest thing is not to go crazy and do something that you'll know will break you car. 5-6K dump will break your stock rear-end.
Things that will hold you back from 12's:
1) gearing
2) suspension
3) tires
4) launch
5) weight
If you have L/T, why would you put 2 1/2" piping on it?
How far do you what to go with your car?
David
1) gearing
2) suspension
3) tires
4) launch
5) weight
David
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
I don't think the catback is hurting the potential much (unless it's a stock catback, in which case swap in an aftermarket one). The 60 foots are what's hurting you, and if the car hasn't been tuned, there's more right there. My Formula (granted it's an auto) with only a lid, FTRA, a flowmaster catback and tuning has run 12.90's in good air, and you have more done than I do. If you're banging the gears and get some traction, you'll should see 12's. As David said, racing breaks stuff (especially on rear ends), so considering adding a rear cover girdle to the 10-bolt as that will help take some of the shock.
Good luck!
Derek
Good luck!
Derek
