All Time Fastest N/A Stock CI, H/C
THIS LIST WILL BE THE TOP 25 TIMES IN EACH CLUB.
Here's the qualifiers: stock cubic inch (any LSX, LTX), any heads, any cam, any tranny, any rear-end, any weight, any pistons, any rods; biggest thing: NO POWER ADDERS.
Please post time slip or video.
Post up: please provide the info in the requested format.
For Updates...
I need your ETs out to three decimal places, (i.e. 11.XXX) and include all the information require for the list.
Updated as of: MARCH 24TH, 2013
Board ID; 1/4 ET @ MPH; Yr & Type of car (ci); Trans; Converter/Clutch; Heads/Cam; Race Weight; Date
1. DMMizell 9.083 149.35 "90 Stang 346;TH350:Ultimate 7200stall, 4.56's, CamMotion Custom Solid,2830lbs,11/20/10
2. Texas Speed & Performance 9.666 @ 130.97 mph ; '98 Z28 Camaro (346); TH200; 5900 stall; H/C; 2858lbs; 10/09
3. JFM-jr / 9.87@134.8 / 99 Camaro SS / 364 LS2 /Performabuilt 4L60E / Circle D 5K stall / G5X4 cam - 5.3 GM head / 3000lbs / 10/09
4. Juggernaut 9.900@134.27; 01 Z28 Camaro (346); T-400; 5000 stall; H/C; 2880lbs; 2005
5. ROBZ* 9.931@138.41; 03 Z06(346); M6; AMR H/C; 3190lbs;12/08
6. Futral 9.959@136.89; '99 Camaro SS (346); M6; RAM Cluth; LS6 heads; SR cam; 3250lbs; 08/05
7. Magnus 9.973@132.78; 97 Firebird (346); LGM H/C; 2900lbs; 11/05
8. OrangeChevyII 9.979 @ 132.39 '88 S10 pu, heads/cam ls3, 2800pounds race weight. TH400 w/ Neal Chance 3400 stall. Pump gas
1. Chrs1313 / 10.08@130.8 (1.29 60ft) / 02 Camaro Z28 / 346 LS1 / FLT 4L60E / Yank SS4000 stall / 239/243 cam - TFS 215 heads / 3050lbs / 11/10
2. Six Speeds Inc 10.110@134.75; 02 Camaro (346); M6; Spec Stg 4; H/C; 3150lbs; 10/06
3. Coach 02 A3 Z/28 10.143@132.33; 02 Z28 Camaro (346); T-350; 5000 stall; Patrick G-comp cam; 5.3 GM heads; 3200lbs; 4/25/09
4. dennis50nj 10.163 @ 131.08 (1.348 60ft) 2005 c6/364 LS2/ a4 4L65E/ 3800 yank/ Cartek stage3 H&C/ 3260LBS/ 3/15/13
5. fasttagirl 10.20 @ 135mph; 2000 Trans Am 347; 4L60E; Yank PT4000 stall; Crane Cam; AFR 205s; 3000 lbs; 10/09
6. Smokin01ta10.219@132.29; 01 TA (346); M6; Spec4; Stock/TRex; 3010lb; 3/06
7. Anit Skeered 10.24@128.7; 64 Chevy II (346); TH400; 239/243 cam motion; 2660; 5-3-09
8. TurboStangJon 10.31@127 Can you please update my time? 01 SS Stock Bottom End LS1 PRC 2.5 5.3 Heads, MS3, 4.10's, TH350, FTI 5000, 3000lbs, 275 Radials.
9. WS6TransAm01 10.326@132.35; 01 TransAm (346); M6; CARTEK Clutch; CARTEK 4X heads/cam; 3300lbs; 12/07
10. GrannySShifting 10.33 @ 131, 1.43 60', 00 TA, TH400, 5000UCC, 3.73 , LS6 longblock, PSI 240/244 cam, 3085 lbs 11/7/10
11. YO-EL 10.35@130.45; 00 Corvette (LS2-366); A4; FTI 3800; CARTEK H/C; 3540 lbs; 12/08
12. TTPMatt 10.35@129.42; 98 Camaro (346); TH350; 5500 Stall; TTP Stage 4R Heads/Cam; 3140lbs; 05/07
13. Torkman15 10.372@132.70; 00 SS Camaro (346); M6; Spec Stg 4; H/C; 3400lbs; 08/06
14. NHRAFORMULA00 10.437@126.37; 00 Formula (346); A4; Pt4400; PRC 5.3;MS3 Cam; 3275lbs; 11/08
15. JaSSon 1.46 10.447 @ 128.28.; 00 SS Camaro (346); A3 with ATI 8" verter; TEA 1.5s; X1 Cam; 3330lbs; 03/09
16. N2RacingLS1's 10.475@127.19; 1998 Formula (346); TH400; 4K Stall; AFR225 / Comp Cams; 3370 weight; 2/11.
17. STATIE10.510@132.18mph; 2004 HSV R8 Maloo (346); 4L60E; 6000 stall; GM Motorsport H&C; 3212lb; 4/08
18. Jetnitro 10.59@126.61; 2004 Gto (346); 4L65E; Cartek 4X 243 Heads and 2X Cam; 3,619lbs; 12/08
19. Top Fuel 10.648@126.36; 00 Camaro Z28 (346); A3, ATI4600; TFS 215's; SI7 Cam; 3200lbs; 11/07
20. TNTaddict 10.650@128.01 ;01 Camaro Z/28 (346);TH400 ; 4400 ; H/C; 3275lbs; 12/06
21. JNorris 10.74@125.90; 98 Camaro Z28 (346); 4L60E; TCI-4000; Trick Flow 215 LG 230/230; 3370lbs; 02/07
22. Smokinstorm 10.76@126.00; 00 Camaro SS (346); A4; PT4000; Vengeance H/C; 3300lbs; 05/07
23. Charles Cyrus 10.76@123.62;01 WS6(346);TH350;5K stall; StgII 5.3s;F13; 3150lbs;11/06
24. jason99frc - 10.762 @ 126.25, 2002 camaro, 346, TH400 TCI 3800, 853 HEADS, G5X2, 3175, 01/10/10
25. shortdog 10.81 @ 123.80; 1.45 60'; 99 Camaro Z28 (347); Built 4L60E; SS4000; PRC 5.3; MS3; 3440lbs; 3/30/13
1. Crazyelf; 11.009@122.82;02 TransAm(347); 4L60E; Circle D 2c 4k+; Ai 226cc ls6/Ai 226/234; 3372; 12/29/12
2. MATTREDSS 11.127@120.17mph; 02 35th LE SS (LS1-346); A4; FTI 4000 stall; MS3 cam; Stock heads; 3525lbs; 3/10
3. Tony B4 11.132@125.03mph; 06 C6 (LS2-364); A6; 3200 Vigilanti; Cartek 3x cam; Stock heads; 3350lbs; 10/08
4. BADD SS 11.133 @ 124.63 1.62 60ft 2000 SS (346) Patriot Stage 1 ls6 heads torquer 2 cam M6 Monster level 3 3275 lbs
5. senicalj4579 11.149@122.82 1.661 60' 2001ss (346) 4l60e ss3600 boltons Tea ls6 stage 2 heads comp 228/232 cam 3450lbs 9/12/12
6. pirate3 11.16@121.95; 00 Z28 (346); TH350; TCI 4200; self ported heads; 242/248/.610/.615/111; 3350lbs; 4/08
7. Evilways 11.19 @123 ; 06 Corvette C6 (LS2-364); A6; L92/L76 Heads/Cam; 3470lbs; 11/07
8. studderin 11.27 @ 122.49; 01 z28 (346); M6; RAM; stockheads, streetsweeper cam; 3300lbs; 10/08
9. 4psi 11.368 @ 120.77; 1999 Z28 Camaro (346); A4; TCI 4400;PRC 5.3 stage 2.5/ms3; 3300lbs; 9/08
10. Intercooler2; 11.412@119.11; 2002 WS6 (346); A4; Circle-D 4C; Patriot Stage 2 LS6/Comp 224/228; 3750; 11/21/09
11. JRracing 11.42@120.21, 00 ss (346); T56, oz700, AFR's, 236/236 cam, 4.10, #3550, 2007
12. Tally TransAm; 11.465@122.08; 99 TransAm (346); M6/SpecIII; Patriot 5.3/F11 (228/230); 3500lbs, 12/06
13. BirdofPreyBandit 11.473 @ 116.85; 2000 Formula (346); A4; Yank 4000; Heads and Cam; 3600lbs; 1/09
14. Red 01SS; 11.50 @ 116.33; 01 Camaro (346); A4/3600;
PP 243(228/588);11/08
15. GTO1_OHIO 11.5059 @ 122.36 1.6171; 2004 GTO (346); A4 Rossler; Vig 3200; AFR 205; FTI 224/228; 3545lbs; 11/2009
16. Mac 2002 SS 11.520@117.62 ; 02 SS Camaro (346); A4 ,SS4000 Yank, 3.73 Motives , Livernois Stg II LS6 Heads , F13 Cam , 3900 lbs 10/29/10
17. 04gtod 11.554@114; 04GTO (346); A4/4000SS; Livernois I; 3510lbs; 8/08
18. troopercar 11.567@118.04,2002 Z28 (346); A4/4200; ported 243's, Comp 232/236 dur .595/.601 lift 110 LSA, 3500lbs, 2/28/09
19. LS1HIGHLIFE; 11.584@121.43mph; '00 Z28 Camaro (346); T56/SPEC III; PRC stg2.5, 5.3ltr heads/TSP Torquer II cam; 3595lbs; 17 Nov 08.
20. MAXXLIMIT, 11.610et @115.506/ 98 Pontiac Trans Am/ LS1 346(stock bottom end)/ Yank SS4000/ 4L60E (stock)/ Pratroit Performance Stage 2 LS6 243 heads/ MTI S1 Cam/ 3730lbs w/driver /10-20-2010
21. HSESWS6 11.628@118.71; 00 WS6 (346); M6; Spec 3+; PATRIOT heads/cam; 3350lbs; 06/08
22. 1996z28 11.64@116.7; 98 z28 (346); a4; pt4400; PATRIOT heads ms3 cam; 3550lbs; 02/21/09
23. LilSlo1 11.658@117.13;98 TA (346); 4L60E; Vigilante; Comp XER cam, 806 Heads; 3775lbs; 10/08
24. TractionTroubles 11.676@120.6; 08 A6 C6 (364); stock cam/hds/gears/stall; 3400lbs; 2008
25. Jebuzws6 11.688@116.49mph; 2002 Trans Am (346c.i.); 4L60e; Vigi 3200; PRC stg 2.5 5.3L/ MS3 cam; 3600lbs; 1/8/11
David
For Updates...
David
Old Drag Racer
Best times are in my sig. I don't have any proof other than I didn't actually run the car myself. 11secss did the driving for me. It was in the Spring of 2007 at VMP in Dinwiddie, VA. I only wish we could have run that 6.81 that day at the 1/4 mile. The 10.76 actually came on a 6.86 660' split. The DA was around 700 feet during the run with a raceweight of 3300 pounds. 3120 car, 180 pound driver.
