New Best 9.88@140.86 -- In a Truck
Got a new best yesterday, Also managed a new best 60' of 1.49
Next pass backed it up with a 9.900
The Combo
BOOST AT 13LBS with 75 Shot
Truck is a 2002 S-10 originally a 2.2L 5 gear.
Engine setup is
370 Cube Iron block
Compstar Rods
Diamond Pistons
Trend tool steel pins
Comp Cam
Patriot Stage II LS6's
Yella terra Rockers
Mamo ported Fast
Cleavite Bearings
ARP Studs
Precision T76GTS
Tial 44MM Gate
Tial 50MM BOV
Transmission
Finishline Level 5 60E with Billet Output shaft --- Yes 60E
YANK SS3600 Converter.
Currie 9"
3.55 gears
MT 295/65/15 Drag radial
Nitrous system is from Nitrodave, 90MM Plate kit with the NX Boost referenced progressive controller. Truck Is HP tuners tuned by me.
Its a custom rear mount setup so the engine bay does not look to special.
Here are a couple vid's Unfortunatly not the good ones.
