Removing A/C questions!
15..AC compressor
8.6.AC condenser
21..AC fan motor (entire assembly)
so that would be about 44 and a half pounds...
But my question is i know the condenser is the thing by the radiator, but where is the compressor and the fan motor assembly? Could anyone take a picture of an LT1 engine bay and label them to show me where those parts are? I'm on the fence about removing the A/C and am just curious how much it would clean up the engine bay and it obviously removes decent weight.
Thanks!
Thanks!
The condenser is in front of the radiator.
The compressor is under the power steering pump on the passenger side of the engine.
You'll want to leave the fan assembly since it's also responsable for cooling the engine.
Most will remove all the lines to the evaporator and then leave it open or plug it with somthing like this: http://www.pcmforless.com/index.php?...d=98&Itemid=98 (scroll to bottom)
If you plug all lines once their removed they can be reinstalled later if you want AC back. You can do a search on removing AC and see pics of others who have removed the evaporator, this would be difficult with the engine still in place though!
Your HVAC system performance should not be affected by engine vaccum.
P.S. don't forget to get an AC delete pully to maintain stock belt routing (idle pully which replaces the compressor)
Good luck!!
I just cut the AC Box inhalf, and took the AC stuff out because that sits on the outside of the Fire Wall in the Engine Bay. All the stuff for Heat is behind the Fire Wall in the Passengers Compartment.
Good luck!!
I have to re-do mine, there is quite a few air leaks in the way mine is. I need to make some better ducting for it.
It does the job on high, it feel like it did on medium though. I need to get in there and fix it when I get a chance.
