NHRA Legal Battery Relo... Questions
im wanting to relocate my battery to the trunk area in my 02 ss. to make it NHRA legal what do i need to have?
also if anyone has any tips on doing the relocating let me know.
**also does anyone sell any batt relo kits with everything needed?
thanks
thanks
that is correct. if it is in a sealed box then no need for a bulkhead. the cut-off switch can either kill alternator power or run a 2 pole switch to kill ignition power. either way as long as it shuts the car off when running. if you dont do this than the alternator will keep the car running even after disconnecting the battery.
Also don't forget the J-type hooks aren't legal. If you look under my name I have a wiring diagram posted in this section that is NHRA legal and its the correct way to wire the battery.
-Mark
-Mark
what about if i have a optima which is a sealed battery do i still need a completely sealed off container or can i have like a tray that leaves the battery in sight?
https://ls1tech.com/forums/drag-raci...ator-kill.html
