MT DR's vs MT Slicks Last time out I managed a 1.59 60' on 26" MT DR's. Not bad but now I am upping the power with heads/cam/intake and swapping to a 9" with 3.70 vs the 10 bolt with 3.23's. So I have been wondering how much ET or 60' I may gain if I went to a full MT 26" slick. The car isn't trailered so I would still need to drive to the track on them. With the 9" in place I don't have to worry about beating it like it owes me money :D so I have thought about selling my DR's and going full slicks. Any thoughts? |
My question is it a A4 or M6? If it is an M6 I would say go with the Bias ply ET street for sure. I drive my car around on ET street bias plys all the time. And there is a huge difference between the Radials and the Bias plys in a stick car |
A4 with 3700 Circle-D converter |
It should hook on radials plus be a little more driver friendly. |
Originally Posted by dschmittie1
(Post 11857672)
the radials will hook better and MPH better on an auto car. |
Originally Posted by airforcemanss
(Post 11858827)
so you drive with slicks on the street? i thought you had to have at least some kind of sturdy sidewall to drive on the street? how are they on the street? you must hug on to everything They aren't that bad to drive with on the street. You get used to it. But that comes with driving a car with no front sway bar, slicks and skinnies and a spool on the street |
Originally Posted by gator's 99TA
(Post 11859746)
With current power, def radials. Since there is almost no way in hell you should be over powering the tires. With the new found power, you may find a limitation on the radials if, and I say only if you make corresponding changes to the gears and converter. 3.73's is not considered too wild and that 'verter maybe a little too tight given the cam but until you get out there, you wont know. FYI I do not see any suspension mods, so that should be considered standard as well. Had the car carried 4.10's and a 4000-4500 9" stall then I would say slicks maybe helpful but I do not see the car going that way. Last note, had the car been a M6 car, all the suspension and tire requirements change. |
I have LCA's, PHB, TA, relocations and springs. I don't plan on going to the extreme end of things. |
I'd stay with the drag radials for now, and see how it does. |
you'll do fine on the drag radials. i put down 1.47 with no anti roll bar in the rear, not even a sway bar. it now pulls better with the wolfe anti roll on the drag radials. oh and i sprayed anything from a 150-250 out of the hole. |
They have half tread left or so. Selling them would kind of be hard to judge what to ask so I guess I will burn them off before making a decision. |
i spin threw drag radials at the track..big cam big converter..need bias plys for myself |
I dont see how auto cars are trashing DRs like that, there are cars in the 800hp+ range killin it on DRs.....invest in suspension |
I have ran both tires with my car that runs pretty similar times to yours. I cut a full tenth better in the 60' with the DR's over the slicks. Also, with DR's the car doesn't sway back and forth when I'm driving down the road unlike with the slicks. |
Drag radials will do better than a slick or bias-ply dot slick on a similar size due to less growth in sidewall, less flex and easier top end driveability. My Nova will 60 foot .01-.03 better and mph about .5-.75 better on a 275/60/15 M/T radial versus a 28 x 10 x 15 M/T slick (although I use the slick for transbrake hard launch stuff as a safety deal since radials can be less forgiving). I have been 1.39 60 foot on the radial in a 3600 lb auto car so they do work! Derek |
get some Hoosier DRs :) |
Originally Posted by AChotrod
(Post 12838770)
get some Hoosier DRs :) Your stuck on the hoosiers arent you :D |
OP never stated what size rim the tires were going on...... |
| All times are GMT -5. The time now is 02:45 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
