Drag Racing Tech
Cam only, won't MPH!?!
Old Sep 1, 2009 | 02:33 PM
Bird_Of_Prey's Avatar
Default Cam only, won't MPH!?!
Well, I had another good weekend of racing. I can post the breaks when I get home, but in a nutshell... 1.77 60' 12.59@107????? Something isn't going right. We have scanned and logged the car before, but it doesn't show any knock or timing reduction. I'm starting to lean towards a mismatched combo of parts.
Current cam came with the car. Was told it was 242/242 unknown lift on a 114icl. Anyway to verify this without pulling the cam out? I think the valvesprings are possibly getting tired. Cam was installed at unknown mileage, but I believe it may have possibly been around 03-04.
Also, I think the Flowtech headers are also slowing things down. Anyone else have them, then go to something better? Huge gain? Not worth it? Need some advice here as this is a mess. My previous lid, catback, converter, suspension car went 12.20@112ish? So I was expecting a slightly better # out of my cam car.
Old Sep 1, 2009 | 03:55 PM
ONEBADWS6's Avatar
Drop it off with a bag of cash and a desired E.T
Old Sep 1, 2009 | 04:22 PM
I'd like to run 4's, can you call John Force for me? kthxbai!
Old Sep 1, 2009 | 07:46 PM
4bangermustang's Avatar
MPH seems right for a 12.60 run....
Old Sep 1, 2009 | 09:23 PM
1fast98's Avatar
i agree 12:60 @ 107 sounds pretty close to me.
im only going 116 and almost a full second quicker.
Old Sep 1, 2009 | 09:34 PM
Shawn @ VA Speed's Avatar
you should def be running more mph than that,i got a cust that has gone 120 with cam and headers 2001zo6-those headers are junk,and if those cam specs are correct-it's all wrong for what you have.
Old Sep 2, 2009 | 08:35 AM
Camaro396's Avatar
Originally Posted by Shawn @ VA Speed
you should def be running more mph than that.
No kidding. I went 13.281 @ 107.9mph stock! Hope you get it all figured out man!
PS. With my experience working at our local speed shop, everyone who has purchased Flowtech headers hates them.
Old Sep 2, 2009 | 09:32 AM
ONEBADWS6's Avatar
I'm sure you have an idea of my street car's setup, your's makes it look like a pro stock and I could give you tennis ball shot out of a potato cannon spot. You want it to work right call me and we can sit down and go over everything.
Old Sep 2, 2009 | 09:35 AM
CRASH Bandicoot's Avatar
Take the 340lb girl out of the trunk?
Old Sep 2, 2009 | 09:36 AM
ONEBADWS6's Avatar
Hahahahha jen"s 5.0!!!
Old Sep 2, 2009 | 11:10 AM
This isn't on my Z06. My cruiser F-car.
Old Sep 2, 2009 | 11:11 AM
I'm thinking about starting over with a blank sheet of paper. New car, whole 9 yards.
Old Sep 2, 2009 | 11:28 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
if it isn't at the limits of anything on the bottom end (traction), the 107 mph for a mid 12 second pass is about right. Most stick cars will mph more than an auto at the same e.t.
Derek
Old Sep 2, 2009 | 11:38 AM
5.3LJimmy's Avatar
What gear, trans, and converter setup? Sounds like you may have something going on with the converter.
Old Sep 2, 2009 | 01:59 PM
Stock 3.23 gear, rebuilt 4L60e, 3200 Vigilante. Trans and converter seem fine, shift well, no slippage.
I understand that the MPH is ok for the ET, however, 381rwhp should be slightly quicker...
Old Sep 2, 2009 | 03:01 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Funky shift points or valve float would be the first two things I would check.
Old Sep 2, 2009 | 03:17 PM
JUICED96Z's Avatar
A little off subject but I would say your smalle gears are not helping your combo much.
You should be able to pull the timing chain cover and see what the grind number is (etched into the cam)... just hope it is not on the other side like the last cam I had.
There is a way to test the springs installed on the car, might have to do a Google search on it. You might to a leak down check while you are at it.
If all that checks out and the tune is good then it could be the converter... Did the trans go bad with that converter installed?
Old Sep 2, 2009 | 06:28 PM
When did it make 381?
Was the converter locked?
Old Sep 2, 2009 | 07:28 PM
SSPerformance's Avatar
need to get it back on the dyno and starts checkign **** its deff down on power u shoud be atleats in the 116 range
