Drag Racing Tech
Ugh, rear lexan install didn't go well, need advice
Old 09-20-2009, 06:15 PM
TS6
TS6's Avatar
Default Ugh, rear lexan install didn't go well, need advice
So we installed a speedglass rear window in the TA and I decided since it was one of the pre-blacked out border ones that having it tinted completely first would be smart, that way none of the hatch framework would be totally visible. That meant gluing the window in but it has tint between the glue and glass, and its lifting. I'm concerned the window will pop out, so I'm gonna put some screws in it. Can I just pre-drill some holes around the border and run some countersunk screws into the hatch? Its pretty solid, but the corners have started to peel the tint and it can only get worse.
Thanks
Old 09-20-2009, 07:33 PM
BAKED's Avatar
That's what I would do to it. The only other option I can think of would be to tear it back out, cut the tint back from the area that you are gluing and re-glue it back in.
